97 E350 RKE Module?
Old Jul 18, 2016 | 04:13 PM
dcgayhart's Avatar
dcgayhart
97 E350 RKE Module?
My drivers side door lock will not unlock with the switch or fob. Since it will lock the wiring and actuator are functioning ok. I suspect the RKE Module behind the drivers seat on the wall of the cargo area. I removed it and checked all the pin and solder joints, still won't work. It has no part numbers on it so I can't find a replacement. Anyone else had this problem?
Old Jul 18, 2016 | 11:07 PM
dcgayhart's Avatar
dcgayhart
I have been searching the internet for wiring diagram's/pinouts of the RKE module for trouble shooting with no luck. I cannot even find where to get a replacement module! Maybe better luck tomorrow.
Old Jul 19, 2016 | 01:25 PM
dcgayhart's Avatar
dcgayhart
Visited one local Ford dealer today. Good news is I have a part number F7UZ-15K602-AA, bad new is they are discontinued and no one in the US dealer network has one. If I could find a schematic I could try and repair it or maybe retro fit a later model unit by rewiring the connectors? Still searching for information at this time.
Old Jul 19, 2016 | 06:10 PM
jimbomitch's Avatar
jimbomitch
That looks like it's going to be a tough part to find. If you're in a hurry, I'd start by looking for a used one at recycling yards. Or, wait until one is listed on eBay, if you're not in a hurry.
Old Jul 19, 2016 | 09:34 PM
dcgayhart's Avatar
dcgayhart
Door lock has been out of service for a while, other problems have been on the front burner. I will try and find a salvaged unit but that may take some time. Hard to believe that a newer unit cannot be modified to work, just need someone dedicated enough to figure it out. The RKE module in my van was only used in 97-99 E series.
Old Jul 20, 2016 | 08:32 AM
dcgayhart's Avatar
dcgayhart
If I could find a wiring diagram or the pin outs to the module it could be possible to fix this. There are 6 relays on the board and only 4 locking mechanisms. I presume 2 are spares for other applications. If I could identify the bad one I could swap it with a spare. Hoping someone has this info for me.
Old Jul 25, 2016 | 08:34 AM
dcgayhart's Avatar
dcgayhart
I'm searching the internet for a module. I've set up an EBay search and report, what else can I do?
Old Oct 5, 2019 | 08:28 PM
Aquachimp's Avatar
Aquachimp
I know this post is old, but I think I'm looking for the same module for my 1997 Econoline Powerstroke. Mine didn't come stock with remote keyless entry, but it has a harness in the correct location that has a tag that starts with F7UZ. Everything points to F7UZ-15K602-AA being the part number I need. Just seeing if you ever found a source for this receiver.
Old Oct 6, 2019 | 09:45 AM
dcgayhart's Avatar
dcgayhart
The part, in good working order is impossible to fine. I gave up.
Old Oct 6, 2019 | 07:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F7UZ-15K602-AA .. Receiver - Radio Remote Control / Obsolete
When I typed the part number into the FoMoCo dealers online parts catalog, this is the description.
No Ford dealer or obsolete parts vendor has any, none on ebay.
aquachimp: No harness would have an actual part number prefix or part number. Last year that Ford put part numbers on parts was 1956!
The prefix could be F7U, but the 4th digit would not be a Z
Old Oct 7, 2019 | 03:52 PM
Teutonics's Avatar
Teutonics
One thing to try, mine (2006) stopped working as well. I unplugged it and left it overnight (just by chance) and it seemed to reset itself and has worked fine ever since. Either it did some type of reset or the plug contacts were not seated properly.
Cheap and easy to try...
Old Dec 2, 2020 | 03:04 PM
longboardguy's Avatar
longboardguy
Thanks for the reset tip. I disconnected the neg battery cable, had a beer and dinner. About 2 hrs later, I reconnected the battery and it had reset the RKE.
My fobs and door key pad stopped working one day for no reason.
2006 e350
My RKE module is behind the front passenger kick panel.
Old Dec 3, 2020 | 02:33 AM
turbogus's Avatar
turbogus
If your van is anything like mine....
I've been into the RKE on my '98 E 150 several times and I suspect like other modules on board they've overtaxed the wiring and or there ground issues.
Old Dec 22, 2022 | 10:09 PM
pvaldeben's Avatar
pvaldeben
1st Gear
Same issue here I have a new to me 1999 E150 conversion Van with F7UF-15k602-AA key fob does not work and the door lock button does not either. When I do press the unlock button on the door or key fob, I hear a slight clicking noise in the RKE module F7UF-15k602-AA.
Since they are hard to find, I can only think if it is possible to rewire another Ford RKE module from the same year.
Any Ideas greatly appreciated.
Old Dec 23, 2022 | 04:41 AM
JWA's Avatar
JWA
These modules simply wear out over time which is understandable given the number of duty cycles and rather harsh environment they endure. The modules are also terrifically cheaply built so its a bonus of sorts if they last 10 years.
Rewiring the chassis to accommodate another year in theory isn't too complicated but it does require an EVTM's from the years of the van's that would be used. Should the transplanted RKE module fail again you're back to step one.
If the RKE function is a must have look for a high quality "car alarm" that will have remote control of the PDL's and save yourself a ton of potentially disappointing work and aggravation. I've BTDT and would never consider rewiring the chassis wiring.
Good luck with this!
Adventure Van
Sep 29, 2018 06:59 PM
salazar44
Jan 10, 2017 12:02 AM
1toncrew
Sep 2, 2013 12:40 AM
cookkd
Aerostar
Jan 14, 2006 09:10 AM
Motown Fire
Sep 19, 2004 11:13 PM
