Modular V10 (6.8l)
Alignment
Old Sep 15, 2009 | 05:16 PM
yasky69's Avatar
yasky69
Alignment
Hey guys. Been a while since I've been here but you have all helped me before and saved me tons of money.
Tire wear drivers side inner. Tire is running on the lower inner edge. Is there a way I can adjust camber without taking it to someone to fix?
Old Sep 16, 2009 | 06:50 AM
jonrjen's Avatar
jonrjen
I'm sure someone may come along and tell you how it may be done.
However my thoughts are more along the line of:
A front end alignment is cheaper out of pocket money than a new single tire. So why not do it right one time and be sure of the correct settings. Who knows, it may end up saving you from purchasing two new front tires in the long run. Plus, must dealers offer a second re-alignment with in 12 months or 12,000 miles.....Kind of a 2 for 1 deal.
Old Sep 16, 2009 | 11:23 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds more like something is wrong
Old Sep 16, 2009 | 07:42 PM
Fordfanatic4life's Avatar
Fordfanatic4life
my guess is a worn upper/lower balljoint on that side..
have u checked ur ball joints recently ???
Old Sep 16, 2009 | 09:09 PM
BareBones's Avatar
BareBones
I assume you don't have 2WD? They have a different suspension...
Old Sep 17, 2009 | 07:36 AM
yasky69's Avatar
yasky69
Thanks for your replies guys. Here's where I am with this. I'm a believer that I like to learn how to repair my cars and trucks. I found a bad upper ball joint. So I bought new upper and lowers since I had to tear it all down. I found a site with step by step instructions and pics. What a b!tch! This morning I am have them pressed in and should have it back together in a few hours. My tires are already toast so I'll have to replace them anyways. Seems like most of the adjustments are made through the upper ball joint by using washers with degrees/angles, if that makes any sense.
Old Sep 23, 2009 | 09:00 AM
V10KLZZ71S's Avatar
V10KLZZ71S
You need a camber kit, shims and stuff.
Old Sep 23, 2009 | 09:24 AM
12ozd's Avatar
12ozd
Correct on the camber shims!
If you can change ball joints,you can change the shims.
Only problem,if you don't have a camber gauge,you'll only be guessing.
FEA require special tools that most people don't have.
As posted above,go to a FE shop and get it set correct.(as they will check/set;caster,camber,toe etc..)
Old Sep 23, 2009 | 10:36 AM
wb6anp's Avatar
wb6anp
It is best to do 4 wheel/thrust angle alignment, other wise you could be driving down the road sideways.
Old Sep 24, 2009 | 09:50 AM
yasky69's Avatar
yasky69
Thanks for all your help fellas.
Well I replaced both upper and lower ball joints. PITA, but was a great learning experience. I think I got rather lucky. The camber shims stayed in position perfectly. Whether or not its exact I don't know yet. What I did do (right or wrong), is I used a 2 ft level to make sure that the tire was at least setting level to get an idea if it was straight. Seemed to work ok and now drives down the highway nice and straight.
What I should do know is take it in just to have my camber and toe checked professionally. But until then the tire is no longer leaning and there is no unusal tread wear.
jmunkie13
Feb 25, 2013 05:27 PM
wresleu
Aerostar
15
Jan 12, 2006 06:34 PM
GreatNorthWoods
13
Mar 18, 2004 03:35 PM
Habitat
Aug 6, 2003 11:24 AM
GreatNorthWoods
Apr 6, 2003 08:37 AM
