Missing sticky in Tech Folder
Old Sep 15, 2009 | 10:05 AM
Fordsflylow's Avatar
Fordsflylow
I tried to get access to the 2.3L timing belt linky, but the site that held it has been closed down. Anyone have the sticky or a new link where I can find it?
Thanks!
Old Sep 17, 2009 | 06:01 AM
Fordsflylow
Bump. Specifically I need a the scoop on doing a timing belt change on a 95 Ranger w/2.3L.
Old Sep 17, 2009 | 09:03 AM
tomw's Avatar
tomw
I have it in doc format. I offered several times to send it to the moderators with no response. Send me a message and I'll send it to you.
tom
Old Sep 17, 2009 | 09:13 AM
Traxxis's Avatar
Traxxis
What do you need to know? Do you need the whole process?
From memory... but I warn you, it has been several years since I changed the belt in my '91 2.3L.
You will have to remove the radiator because there will not be enough room to get a socket on the crank. Upon reassymbly, this will make a good time to go ahead and flush the cooling system and replace with new fluids.
You will then have to remove the drive and accessory belt.
You will then have to remove the harmonic balancer (left-hand thread!)... you'll probably need a strap wrench to wrap around the HB while you're cranking on it. I also recommend putting the truck in gear and setting the parking brake, as this may help break the nut loose. I know when I did mine, I had to chaulk the wheels too... it was on there pretty tight. The 96 3.0L I did a few months ago didn't take all of that though.
If I remember right, you can then pop the plastic cover off of the front of the motor and replace the belt. Something tells me though, that I am missing something. Seems like something else had to come off.
Reassymbly is reverse.
Hope this helps.
Old Sep 17, 2009 | 02:45 PM
tomw's Avatar
tomw
The bolt on the nose of the crankshaft is normal right-hand thread.
Lefty-loosey, righty-tightey...
Can't say about the post-Lima 2.3.
tom
AllaboutMPG
Jan 15, 2015 08:53 PM
Fire Rooster
2009 - 2014 F150
48
Apr 20, 2012 07:03 AM
ALBUQ F-1
15
Feb 7, 2011 10:32 PM
huntercgr
Oct 16, 2006 02:35 PM
64fordman
Sep 5, 2003 07:17 AM
