Sponsored by: Auxito
Can't Go in Reverse
Old Sep 15, 2009 | 06:35 AM
Migelio's Avatar
Migelio
Can't Go in Reverse
I have a 2002 4.6L 2WD, I gears are not working one day got in my truck and moved the shifter into reverse and nothing happened, I slammed the gas pedal down and clunk, boom, screech, it jump and skipped backwards, i put it in neutral to try and push it out, but failed it was locked in all gears. After several hard attempts finally got it out enough to drive home 1st and 2nd made a clanking noise added transmission fluid, got on freeway and seemed to be ok then when got home still 1st and 2nd noises and reverse no budging. Any ideas on what the problem could be, Its parked and cannot be driving. Thank you!!!!!
