I've been on the classic truck site for years -succeeding in reviving my 1988 F250 back to life with the assistance I found there. Read some of the posts here and thought I'd ask a nagging question of my own.
I have to cut through vinyl siding to attach a screened in porch addition. The vertical posts and the end rafters of the porch will lay against the existing house wall. I was going to make a cutting jig and use a small tooth blade on my cordless circular saw to make the cut. My question is are there any other ideas on making the cuts and how can I put in the neccesary J moldings over/under the cut ends of the vinyl after attaching the posts and flashing the shingles against the house? I've worked with wood siding for years and this wouldn't pose as much of an issue.
It would save you time and agrivation to take the siding off before you do the addition. because you have to nail j molding behind the siding and nail and caulk the flashing behind the siding as well. oh don't nail the siding tight leave the nails about 1/16 to 1/8' loose, and cut the siding a1/4 or more short, this gives the siding room to move with expansion and contraction.
x3
It will take less time, you will have a better job and it will look nicer if you just remove the siding, build what you are building, then install the correct flashings and trim and the siding.
Thinking about this later ,I thought it may be a good idea to number ,of label the siding on the back side so its easier to reinstall in the right places , also , you may want to replace the vapor barrier , unless the nails go back in the same holes .
Yeah, I would put new vapor/air barrier up (you can use 15# felt, 30# is better, house wrap is the best) and dont nail into the existing holes, unless the shank of the nail is bigger than the hole.
I wouldn't use felt. Use Tyvek wrap. Remember went you renail the siding do not nail the sliding tight. The siding must be able to move with heat & cold. I sided several houses for a Government contractor at a military base years ago. We just cut siding with tin snips, & razor knives.
Craig
Nails in the same holes help with lining up the courses when you put them back on, but don't hold at all....
I thought it might be easier to get the siding straight if he used the old nail holes ...
There are plenty more places to put new nails if he decides to go that route . It will save the cost of a new vapor barrier & block air intrusion ... (but you have to fill all the old nail holes ..
Personally, I wouldn't leave the siding 1/4" short at or near the hottest temperatures your area sees during the year. I'd make it almost tight. It will only shrink from there...
Also, if it's very far below freezing, just don't bother. You'll break more than you install.
