Modular V10 (6.8l)
New with questions??
Old Sep 15, 2009 | 12:05 AM
mrclean667's Avatar
mrclean667
First off hi and thanks for having this forum!!
Second, how do I find out what gears are on my 2000 F250 V10. I do tow and would like to have the best possible package for towing. I do notice that when I tow my camper it is ok on flat road but any hill or garde increase kicks it into overdrive..
Third, I need to know how to safely take off the steering wheel pad to get to my horn contacts. when I put the fuse back in the horn constantly goes off. This started a few months back.
Thanks in advance for any help you guys and gals can offer!!
Old Sep 15, 2009 | 04:15 AM
scraprat's Avatar
scraprat
Top Answer: 5
There should be a small tab on your rear axle cover plate with #s and possible a letter.
As for you steering wheel sorry can't help never had to do it. Haynes manual should help you out, can get them at any auto store usually.
Old Sep 15, 2009 | 07:07 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
First, WELCOME to FTE!
The small tag under a bolt on the rear cover might have the first number covered by the bolt head. So it'll say something like "L 73" or "L 30" or "L 10" or " 10" or " 73" or " 30" ...
The "73" is a 3.73, the "30" a 4.30 and the "10" a 4.10. The "L" stands for limited-slip.
Otherwise, just get the axle code from the door sticker and look it up in the Tech folder in the Superduty forum.
Old Sep 15, 2009 | 07:08 AM
krewat's Avatar
krewat
Oh, the horn thing is either the contacts like you said, or the clockspring is broken (although that usually makes it NOT work).
Old Sep 15, 2009 | 08:54 PM
biz4two's Avatar
biz4two
Arrow
Welcome to FTE!
Rule of thumb for towing with the 4R100 tranny is that when you hit the hills or driving in town with a heavy load turn off the OD. It saves the tranny from getting to hot from shifting (hunting) in and out of OD.
What I do...is right before I hit the hill or steep grade, I turn off the OD and let the V10 do its thing by revving it up in the 4000+ rpm range. When I hit the flats...I turn OD back on and cruise down the road.
Hope this helps...
biz
