new floor pan issues
Old Sep 13, 2009 | 09:11 PM
mudder460's Avatar
mudder460
I am putting in my new floor pans but I am running into a problem. The tranny crossmember bolts are hitting the new floor pan. I can't get the new floor pan down far enough to weld it to the cab mount. My old pans had holes where the bolts were sticking through. I was told they were not supposed to stick through like that. Does anyone have any imput? I am about to drill holes just to get it done.
Old Sep 13, 2009 | 09:22 PM
benmoderow's Avatar
benmoderow
What about taking the bolts out and flipping them upside down? Or using carriage head bolts. Just an observation.
Old Sep 13, 2009 | 10:12 PM
m j's Avatar
m j
or just grind em down
Old Sep 14, 2009 | 02:32 AM
75F350's Avatar
75F350
If you turn them the other direction they will never come out unless you lift the cab, so they are installed this way for a reason. They can be cut down, you only require two threads above the nut to be safe. This should be fine.
Cut them down and you should clear the new sheetmetal.
Has the cab dropped down for any reason? Is the body mount in good shape or is it crushed and permitting the body to sit lower?
Old Sep 14, 2009 | 09:59 AM
mudder460's Avatar
mudder460
I was thinking about cutting them down some. I thought by replacing the body bushings it would pick the cab up enough to clear them, but it didn't. The cab mounts are fine, not rusted or crushed.
Can someone get a pic of theirs so I can see if there is any differance?
Old Sep 14, 2009 | 10:42 AM
75F350's Avatar
75F350
Would love to help you out with a pic but I dont have a single truck with a stock crossmeber any longer. I usually remove all of that stuff and fab up a costom piece.
Old Sep 22, 2009 | 05:20 PM
smoke20's Avatar
smoke20
here's a pic of mine hope this helps
Old Sep 22, 2009 | 08:53 PM
mudder460's Avatar
mudder460
Well that shoots my theory down of it being something to do with it haveing a 435 in it. I looked at a truck with an auto and it had a similar setup like yours. I don't understand why mine is like this. Everything is factory on the truck. I am just going to put the holes in the new floor pan and press on. I give up on trying to figure it out. Thanks for the pics though!
Old Sep 22, 2009 | 08:58 PM
benmoderow's Avatar
benmoderow
Those look like they're put in from the top down to me. It would be a simple fix and what are the chances you'll ever need to get those bolt out? The original ones have probably not been out in 30 years, and you'll still be able to get the cross member out if you need to. But to be honest, 75F350 is the man so I would follow his advice.
Old Sep 22, 2009 | 09:05 PM
montana_highboy's Avatar
montana_highboy
I would just take a cutting wheel to the bolts before i cut holes in my new floor pans.
Old Sep 22, 2009 | 09:09 PM
mudder460's Avatar
mudder460
I am starting to think about this. Worse case I would just leave the bolts in if I dropped the crossmember. I am just going to flip the bolt and save my pan.
Old Sep 22, 2009 | 09:13 PM
benmoderow's Avatar
benmoderow
Yep, if you need to remove crossmember, just spin the nuts off and drop it out. I definetly wouldn't cut holes in your new floor pans after all the work your going through to put them in.
Old Sep 22, 2009 | 10:15 PM
Jermafenser's Avatar
Jermafenser
What is fastened to these bolts? The radius arms?
Old Sep 22, 2009 | 10:38 PM
mudder460's Avatar
mudder460
No, just the transmission crossmember.
Old Sep 23, 2009 | 02:30 AM
bmarkline's Avatar
bmarkline
I just put shorter bolts in mine but cutting them works too.
