1977 f 250 power steering
They can be rebuilt but are very expensive to do so, most guys just do the 78/79 p/s swap when it comes to that.
This is how I did mine. I used a gear box from a 78/79 F250 4x4 along with the drag link. A little fabrication work, but works pretty good. I ditched the stock steering rod and went a Borgeson steering rod that is adjustable and much better than stock. A few other things I had to do was notch out the radiator support a bit to clear the gearbox. The power steering pump pulley comes close to the gearbox, but works.
You do some great work there Buck.
I went a slightly different direction, and used a Saginaw box. Many boxes are, or have been used, and some are less desirable than others. Three bolt 1/2 ton 4x4 boxes have been used as have the 2wd boxes. Unfortunately the 2wd box has such a long sector, and has some funky angle it is just not a very good box for this upgrade. Another variable is crossover steering, and this 2wd box is just useless.
If fab skills are not up to cutting a frame / crossmember, you can add the three bolt box donated form a 78/9 F150 or full size Bronco right to theoutside of the frame, but this requires some sort of crossover steering or inverted "T" at a minimum.
Some pics of the Saginaw:
Welcome to FTE
Bendix Power Assist P/S was used on 1974 F250 4WD's from serial number T80,001 and 1975/77 F250 4WD's (all "High Boy's").
D4TZ3A540A .. P/S Ram Cylinder / Obsolete
KARLSON MOTORS in Ketchikan AK has 1 = 907-225-9022.
GREEN SALES CO. in Cincinnati OH has 3 = 800-543-4959.
No other Ford Dealer or obsolete parts vendor has any.
D4TZ3A764A .. Ram Cylinder Seal Kit / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606-787-5293.
No Ford Dealer, no other obsolete parts vendor has any.
The following users liked this post:
