Truck Alignment(?)
Old Sep 13, 2009 | 12:46 AM
JTyler11688's Avatar
JTyler11688
Truck Alignment(?)
So my truck has thrown a new symptom at me. I live in Spokane ad the roads have a decent crown to them, and with even the slightest tilt to the road my truck with track down the slope and I have to turn into it. My steering isn't loose, and if the road is flat my truck drives straight as an arrow. Would it be bad alignment, or does anyone have any ideas how to fix it?
Old Sep 13, 2009 | 01:05 AM
95_Dually's Avatar
95_Dually
If the road is crowned your truck heads down the slope?
If the road is flat your truck drives straight?
If I am reading this correctly, it sounds like the alignment is perfect.
Old Sep 13, 2009 | 06:24 AM
etldak's Avatar
etldak
Have the toe adjustment set to toe in more this works prety good when i alin. osb's
Old Sep 13, 2009 | 08:14 AM
Talyn's Avatar
Talyn
If the alignment is good, it will track down the slope, and you have to turn in.
Old Sep 13, 2009 | 08:37 AM
JTyler11688
The road is crowned, but I've driven several trucks on these roads and never had to turn in as much as I do now. I guess I'll check the toe in and go from there.
Old Sep 15, 2009 | 05:43 PM
Erik Sink's Avatar
Erik Sink
Just throwing this out there:
If the caster setting on your front axle is excessively high, the truck would tend to drift sideways down the crown more so than if the caster was in spec. I don't know what kind of lift/susp. mods you've done to the front end, but when I lifted my truck, the front end caster increased noticeably. I have the TTB D50 and the lift composed of drop pivot brackets for the inboard sides of the split axle, and new springs. Just a thought that popped in my head driving down the highway today...
Old Sep 15, 2009 | 06:07 PM
Talyn's Avatar
Talyn
Erik, your truck looks like mine.
Old Sep 15, 2009 | 06:20 PM
Erik Sink's Avatar
Erik Sink
Nice! They're beauties
Icicle
May 7, 2014 10:07 AM
dloomis
Washington Chapter
Feb 18, 2013 05:18 AM
jhooch
1961 - 1963 F100 Unibody
Jul 20, 2011 12:02 AM
2001400ex
Nov 9, 2009 06:21 AM
ZMan_AK
New Member Introductions
Sep 8, 2007 07:00 PM
