General Automotive Discussion
its not ford
Old Sep 13, 2009 | 12:05 AM
40dog's Avatar
40dog
its not ford
well im helping my buddy with a camaro he has its a 67 - 327 2sp power glide and I could use some help finding the point gap and the plug wire diagram . i know its not ford but you guys are my regular life line with my truck and my be one has a old chiltons or some thjing with the specs. thanks
Old Sep 13, 2009 | 12:48 AM
Ford_Six's Avatar
Ford_Six
.019" according to Google.
Old Sep 13, 2009 | 01:28 AM
95_Dually's Avatar
95_Dually
The firing order is 18436572. The point gap is .018-.020.
Old Sep 13, 2009 | 08:06 AM
40dog's Avatar
40dog
Thanks guys
I set the points this morning and it runs its alive
we rebuilt the carb yesterday poped in the plugs now its running and sounds a little choppy i hope we didnt miss a gasket in the carb the carb kit was full of stuff not for this one lots of gaskets with lots of different hole patterns auto and marine
i will time it and let you know once i find the timing specs thanks again
right know i need to get the truck dirty
Old Sep 13, 2009 | 02:01 PM
Lazy K's Avatar
Lazy K
Plug gap .035, idle speed with A/C on is 500rpm and timing is 8degrees BTDC. Don`t forget to pull vacuum advance pipe before setting timing.
Old Sep 13, 2009 | 02:54 PM
jade79's Avatar
jade79
You can also "fine tune" things a bit by checking the proper dwell of 28-32 degrees.
http://www.tpocr.com/camaro1.html
See step 4 and 5 on the link below. The 327 distributor cap should have a small metal door you can lift up and adjust the dwell with an allen wrench while the motor is idling.
http://www.secondchancegarage.com/public/670.cfm
Old Sep 13, 2009 | 07:19 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
That's a term I haven't heard in a hundreds.
Tim
Old Sep 13, 2009 | 07:29 PM
40dog's Avatar
40dog
a job well done guys it seems to be runnig good . and my buddy is real impressed . left a 50' burnout with out trying .
Old Sep 13, 2009 | 08:47 PM
85e150's Avatar
85e150
Is this an unmolested '67? Should be worth some bux. Tell him not to pitch it into a power pole doing burnouts....
Look at some of the prices here:
http://www.cars-on-line.com/camaro.html
These might be a little soft now, but originals for Mustang and Camaro are still high, and will go higher.
