Unidentifiable engine?
Old Sep 12, 2009 | 11:41 PM
runnin ranger's Avatar
runnin ranger
I have recently purchased a ford engine and suspect it is a 351 but I cant find any date codes or casting information on it anywhere. All I have found is 351 wcp 20 in the lifter valley. It has an aluminum 2 barrel intake on it that shows the ford emblem on it but that is all that is on it. The engine block and heads also have this strange lack of visible numbers. I am really curious as to what it is that I have gotten my hands on. Any help on figuring out what this engine is before I start working on it would be of great help.
Old Sep 12, 2009 | 11:50 PM
jeramy's Avatar
jeramy
Old Sep 13, 2009 | 06:06 AM
ozstang65's Avatar
ozstang65
Or it could be a 351C = dry inlet manifold and 8 bolts on the rocker cover gasket. Or it could be a 351M which I think is the same configuration as 351C with a much bigger block and big-block bellhousing bolt pattern. Or, if you are in Aus it could be a 351G.....
Old Sep 13, 2009 | 10:24 AM
jeramy's Avatar
jeramy
351 Windsor
5-bolt straight valve covers
radiator hose to the intake manifold
5/8" spark plugs
351 Cleveland
8 bolt 2-plane valve covers
radiator hose does not connect to intake
14mm spark plugs
Old Sep 13, 2009 | 10:28 AM
jeramy's Avatar
jeramy
quoted from ctubutis
I believe the Windsors & 302s have 6-bolt valve covers, not 5. The only Ford
engines that use 5-bolt covers that I'm aware of belong to the FE series
(360/390/427/etc). Yes, the 335-series blocks (351C/351M/400) use 8-bolt valve
covers, and they also utilize an exhaust crossover in the intake manifold, not a
coolant crossover (hence the thermostat going into the block, not intake
manifold).
Another easy ID method - all 335-series engines use the same fuel pump with
the bolts vertically opposing each other, not horizontally.
In my opinion, the 4V Cleveland (especially 1970 version; my mom had one,
and it's one of the cars I learned to drive a stick in as a kid)) is a GREAT
high-RPM screamer that has no place in a truck where low-end torque is the
primary need. The 2V Cleveland needs to be converted to a 4V variant (which
means 4V heads, too (preferably the Aussie variant) and not merely the intake
manifold & carb).
Just my opinion.
Old Sep 13, 2009 | 04:46 PM
runnin ranger
Thanks for the help on identifying this engine. This has raised another question on the engine. Did ford make any heads that took a motorcraft ags 42c spark plug that would fit on a 351w block? This spark plug looks like it is the size of a gm plug if not smaller. It does have 6 bolt valve covers.
Old Sep 13, 2009 | 09:45 PM
ctubutis's Avatar
ctubutis
rockauto.com could find no applications for those things; amazon.com tells us:
Compatibility Chart
<table class="compatibility" border="0" cellpadding="4" cellspacing="0"><tbody><tr> <th scope="col" class="colheadL">Make</th> <th scope="col">Model</th> <th scope="col">Year</th> <th scope="col">Engine</th> <th scope="col" class="colheadR">Notes</th> </tr> <tr class="listRowEven"> <td> Buick
</td> <td> All
</td> <td> 1976-1979
</td> <td> 1.8L L4
</td> <td> Suppressor Copper Plug
</td> </tr> <tr class="listRowOdd"> <td> Buick
</td> <td> All
</td> <td> 1982
</td> <td> 1.8L L4
w/FUEL INJ
</td> </tr> <tr class="listRowEven"> <td> Buick
</td> <td> All
</td> <td> 1983
</td> <td> 1.8L L4
</td> <td> All
</td> <td> 1984-1986
</td> <td> 1.8L L4
w/o TURBO
</td> <td> Opel
</td> <td> All
</td> <td> Skyhawk
</td> <td> 1982
</td> <td> 1.8L L4
w/FUEL INJ
</td> <td> Skyhawk
</td> <td> 1983
</td> <td> 1.8L L4
</td> <td> Skyhawk
</td> <td> 1.8L L4
w/o TURBO
</td> </tr> <tr class="listRowEven"> <td> Chevrolet
</td> <td> All
</td> <td> 1976-1980
</td> <td> 1.8L L4
</td> </tr> <tr class="listRowOdd"> <td> Chevrolet
</td> <td> LUV
</td> <td> All
</td> </tr> <tr class="listRowEven"> <td> Chrysler
</td> <td> All
</td> <td> 1982
</td> <td> 2.2L L4
</td> </tr> <tr class="listRowOdd"> <td> Chrysler
</td> <td> All
</td> <td> 1983-1985
</td> <td> 2.2L L4
</td> <td> All
</td> <td> 1984
</td> <td> 2.2L L4
</td> <td> All
</td> <td> 1984-1985
</td> <td> 2.2L L4
</td> <td> All
</td> <td> 1986
</td> <td> 2.5L L4
</td> <td> All
</td> <td> 1990-1992
</td> <td> 2.5L L4
</td> <td> All
</td> <td> 1982-1985
</td> <td> 2.6L L4
</td> <td> All
</td> <td> 1994
</td> <td> 3.3L V6 FLEX U
</td> <td> All
</td> <td> 1994
</td> <td> 3.3L V6 GAS U
</td> <td> All
</td> <td> 1994
</td> <td> 3.3L V6
</td> <td> All
</td> <td> 1976-1981
</td> <td> 5.2L V8
</td> <td> All
</td> <td> 1983-1988
</td> <td> 5.2L V8
</td> <td> All
</td> <td> 1989
</td> <td> 5.2L V8
</td> <td> All
</td> <td> 5.9L V8
</td> <td> Concorde
</td> <td> 1994
U ENG CODE
</td></tr></tbody></table>
http://www.amazon.com/gp/product/com...au_pf_dp_chart
Old Sep 13, 2009 | 10:07 PM
Jmeyer1990's Avatar
Jmeyer1990
Originally Posted by jeramy
351 Windsor
5/8" spark plugs
351 Cleveland
14mm spark plugs
ok, I have a problem with the windsor part.
i have heard twice on here that it is a 5 bolt valve cover.
then why does mine have 6.
same with all the others I have seen at the junkyard.
are people being mis-informed, or am I coming across dozens of rare-engined trucks?
http://www.motorchrome.com/servlet/t...,covers/Detail
6 bolts
Old Sep 13, 2009 | 10:22 PM
jeramy's Avatar
jeramy
nope that info was pulled from a different thread and i just copy and pasted.meant to go back and fix it to say 6 but apparently you can only edit your last post.
Old Sep 13, 2009 | 10:23 PM
Jmeyer1990's Avatar
Jmeyer1990
nope that info was pulled from a different thread and i just copy and pasted.meant to go back and fix it to say 6 but got side tracked
haha ok.
this isn't the only place i've seen them listed as 5 bolt valve covers.
even some places where people talked about their builds had them listed as 5 bolt 351 windsors.
is counting too hard to do?
351wf250
Aug 6, 2015 02:32 PM
1979redf250
Jun 4, 2014 12:37 AM
NewTune
Jul 9, 2013 06:21 AM
dazedrodeo
Jun 13, 2007 10:16 AM
95ford4x4cowboy
May 14, 2005 09:30 AM
