need oasis report please
Old Sep 12, 2009 | 09:08 PM
Jbrown8988's Avatar
Jbrown8988
if someone could help me out on an oasis report for a 05 f-350
vin# 1FTWW33P75EB74077
Old Sep 12, 2009 | 09:57 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
You'll have to get it from a dealer. This site isn't giving them out anymore.
https://www.ford-trucks.com/forums/7...vin-tools.html
Old Sep 13, 2009 | 09:34 PM
jboczar's Avatar
jboczar
Cust Comments: CUST STATES AFTER DRIVING AND VEH HAS A WARMED UP AFTER HE TURNS IT OFF AND IT SETS FOR A SHORT TIME,HE CAN COME OUT AND VEH WILL NOT START,YOU HAVE TO CRANK AND CRANK TO GET VEH TO START,
Tech Comments: CHECK OUT USING HARD NO START DIAG. GUIDE EEC TEST KOEO PASS KOEC P2291 NO START FOR KOER PINPOINT TEST ICP READ 260 PSI CRANKING REMOVE BOTH VALVE COVERS CHECK FOR OIL LEAKS OK DO BLOCK OFF TEST BOTH OIL RAILS BLOCKED 290 PSI AIR TEST LEAK IN BACK OF ENGINE REMOVE IPR FOUND METAL IN SCREEN REPLACE HIGH PRESSURE OIL PUMP, IPR AND OIL PUMP FITTING REASSEMBLE
Cust Comments: RECALL DEGAS BOTTLE FILL LVL LABL AND FLUID ADJ RECALL 05B32
Tech Comments: 79514 RAN ON OASIS VERFIED CONCERN DID RECALL 05B32 INSTALLED DE GAS BOTTLE LABEL ADJUSTED COOLANT LEVEL
Cust Comments: CUST STATES VEH HAS LEAK AROUND TURBO AND VEH SMOKES AT TIMES LACKS POWER IF ONLY WARMS UP FOR 5 MINUTES VEH SKIPS
Tech Comments: 79528 VERFIED CONCERN OIL ON TOP OF ENGINE PUT BLACK LIGHT DYE IN ENGINE OIL TEST DROVE BLACK LIGHTED FOUND OIL LEAKING AT TURBO OIL SUPPLY LINE AT TOP GASKET REPLACED GASKET FOUND OIL LEAKING AT TURBO CAC HOSE REPLACED TURBO CAC HOSE TEST DROVE REBLACK LIGHTED DO NOT SEE ANY MORE LEAKS
Cust Comments: RECALL EXHAUST PRESS SENSOR REPL. OBD SYS RECALIB RECALL 05E15
Tech Comments: 79514 RAN ON OASIS VERFIED CONERN DID RECALL 05E15 REPLACED EBP SENSOR RECALIBRATED PCM TCM FICM TO 5U7A 12A650 CUF LEVEL OPERATION 05E15M B C 1 0 05
Cust Comments: RECALL 1 TIME CUST ASSURANCE TEST DRIVE RECALL 59B01
Tech Comments: 79528 RAN ON OASIS VERFIED CONCERN DID RECALL 59B01 TEST DRIVE TEST DROVE TRUCK TRUCK DID OK
