Newbie help/advice please!!
Old Sep 12, 2009 | 07:56 PM
IowanStraight6's Avatar
IowanStraight6
Question Newbie help/advice please!!
Hey everybody can you tell me what a 1993 f250xlt 7.3idi non-turbo 87,000 miles 4x4 manual locking hubs is worth they want 4900 is this a good deal? Is this a good motor other than it eatting starters? how long will it last? What should I look at if i go to buy it? What type of milage should i expect it has e40d and i dont know rear end but lets say 3.55? Also i plan on if i get it injector cleaner, flush radiator, tranny fluid and pan, oil change, fuel filter, glow plugs anything im missing? what are weak points of this truck? thank you so much!!!!!
Old Sep 12, 2009 | 08:27 PM
joe f350's Avatar
joe f350
eating starters ? i have seen the go in to the 300k area
Old Sep 12, 2009 | 08:35 PM
IowanStraight6
thats what i heard from my friend that is manager at advance auto he told me to go with a lifetime warentey one when it goes bad if i get this truck cause hes seen them go bad especialy in our cold winters
Old Sep 12, 2009 | 09:48 PM
wdhille's Avatar
wdhille
Are you sure it really has 87k miles? My 06 car has that many...
Old Sep 12, 2009 | 10:25 PM
IowanStraight6
Ya heck my dad bout his 96 f150 year ago with 80000 on it
Old Sep 12, 2009 | 10:42 PM
Dave Sponaugle's Avatar
Dave Sponaugle
87,000 miles is almost a new truck.
Winter has little to do with short starter life, fuel system problems, battery and electrical system problems and glow plug system problems compounded by cranking the starter to long with no cool down period kills starters.
You should check the SCA's in the coolant and maiintain them at propper levels.
Oil, oil filter, air filter and fuel filterare a good start on the engine, also check the glow plugs, belts and hoses.
Changing tranny fluid and filter should help keep the tranny happy.
Check the transfer case fluid level, front and rear differential fluid level and grease everything that has zerks on it.
Changing the transfer case and differential fluid is also a good thing to do.
4 tie rod zerks, 4 ball joints, 7 universal joints if everything has greasable parts installed.
Brake fluid, brake shoes and pads, power steering fluid also need checked.
Old Sep 13, 2009 | 09:43 AM
84 f250 6.9's Avatar
84 f250 6.9
I get 18-20 with mine drivin 50mph and I have 4:10s
Old Sep 13, 2009 | 03:49 PM
pmelah's Avatar
pmelah
i was getting 21 mpg with a bad E4OD tranny now i get 0 it dont go no more that will change with new tranny
