Pulling a steering wheel
Old Sep 12, 2009 | 02:15 PM
Rads 79's Avatar
Rads 79
When pulling a steering wheel, what do you do when you try to put the bolts in the steering wheel to pull it and the threads in the steering wheel have been stripped? Do you have to pull out the tap and die set to get threads put back in?
Would love your insight on this...thanks....
Old Sep 12, 2009 | 02:20 PM
75F350's Avatar
75F350
You can yank it off, or you can thread new threads and start again. There was a thread on this exact issue about a week or two ago.
My aploogies, welcome to the site.
Old Sep 12, 2009 | 04:16 PM
Rads 79's Avatar
Rads 79
I put new threads in and it worked....thanks...
Old Sep 12, 2009 | 04:22 PM
ranger429's Avatar
ranger429
Putting fine threads in there was the worst thing Ford did, should of used 5/16" coarse in my opinion.
Old Sep 12, 2009 | 04:39 PM
63' f100's Avatar
63' f100
I just stripped mine today. Rethreading them bigger is the only thing i could think of. i haven't done it, but I'm glad that i found this.
I have a f100 and i cant get the wheel off and i ruined the threads that are on the bolts on the wheel puller that i rented.
But i have a bigger problem. the center bolt that you turn to remover the wheel deformed the threads on the center and i cant put the nut back on. any suggestions on how to fix that?
Old Sep 12, 2009 | 04:43 PM
ranger429's Avatar
ranger429
Did you simply mushroom the stem out or did you tear the threads up on the column shaft? If you tore the threads up you are going to have to find a die and fix it. If there mushroomed a grinder will help take away the edge.
Old Sep 12, 2009 | 05:03 PM
63' f100's Avatar
63' f100
I just kinda mushroomed it. I'll tap it later and hopefully my dremal will save the day...
Snowseeker
37
May 31, 2017 04:48 PM
gtcrackers
Apr 7, 2015 03:57 AM
Green72F250
Jun 26, 2014 02:40 PM
creedua
19
Jun 11, 2014 01:01 PM
sum_weirdo
Oct 25, 2011 02:02 PM
