y block general question - 55f100
Old Sep 11, 2009 | 10:21 PM
SunDown's Avatar
SunDown
I found a 55 f100 that I will be picking up and it comes with a y block that is in a seperate cutoff front frame stub and the engine looks to be in original condition and was reported to be running a year ago (not holding my breath though). not knowing much about y blocks, can someone tell me what the y block engine options were for 55? is there a following for these engines? Point me in the right direction please!
thanks all!
Jason
Old Sep 11, 2009 | 10:27 PM
hiball3985's Avatar
hiball3985
thanks all!
Jason
Lots of people still run Y blocks. I would suggest you also scroll down to the Y block section in the engine forums.
Old Sep 11, 2009 | 10:52 PM
Kurt G.'s Avatar
Kurt G.
1955 I believe was 239 Y-block. Later years were 272 and 292. If you have the front frame section do you know what year its from. You should check the Y-block section for casting numbers. If the frame is without fenders then you should be able to find/read them. Kurt G. Y-blocks rule.
Old Sep 11, 2009 | 11:01 PM
pcmenten's Avatar
pcmenten
239 and 256. Go to www.ford-y-block.com for technical information. Try www.y-blocksforever.com for advice. Ask for Ted. John Mummert has started contributing, too.
Old Sep 12, 2009 | 03:23 AM
55 f350's Avatar
55 f350
no expert , but the base one was a 239 , and there was a larger one for the bigger stuff . don't know for sure , and i had a 239 in my 55 , but have the understanding that the 239 had a lot of weird one off stuff onto itself . im not saying it's a bad motor but i think i'd find a more common 292, or 272 , good luck finding a 312 , and run one of them as the parts and motors seem to still be fairly plentiful . got a 292 sitting around here again . had a 239 , 272 a 292 , and so forth sitting here once before sold it all ......
Old Sep 12, 2009 | 11:49 AM
HT32BSX115's Avatar
HT32BSX115
Howdy, the 239 and 256 were "IT" in 55. There were Lincoln "Y-blocks" but they didn't have much similarity to the Fords.
You can use ANY Ford Y-block in a 55 though. I've got a 60 292 just about ready to go in mine.
Old Sep 12, 2009 | 04:40 PM
Phoenixson's Avatar
Phoenixson
Rick, Your reply piqued my interest. I'm curious what factors influenced your decision to stick with the Y-block and go with the adapter and the E4OD? My 53 f100 has a 292/312 (not sure which) and I like the simplicity of it, but I hate the 3-speed, and the Bentsten (sp?) adapter is pretty spendy! I had been looking for a 351/aod to go in it but now you have me thinking about keeping the Y.Please elaborate.
BTW.........cool truck you have there!
thendrix
18
Jul 15, 2011 11:07 AM
TxF100
Jan 24, 2009 03:33 PM
bolivious
Nov 15, 2006 10:55 AM
bolivious
Nov 10, 2006 06:12 PM
bseinwv
Nov 29, 2005 06:05 PM
