Trans pan leak
Old Sep 11, 2009 | 11:46 AM
Stroked Out!'s Avatar
Stroked Out!
Trans pan leak
I can not get the leak to stop after i changed the fluid and filter I even tried the gasket that it came with and still leaking anyone with and suggestions please its driving me nuts!!!!!!!!!!!!!!
Old Sep 11, 2009 | 12:00 PM
MoyockPowerstroke's Avatar
MoyockPowerstroke
If it was the rubber gasket (flimsy) that came with the internal filter...I wouldn't use it. The OEM gasket with the metal reinforcement is reusable. Just clean it up with some dawn dishwashing liquid, dry it off and reuse that instead. I also had a leaking area on the flange that caused me to start over with using a liberal amount of Permatex around the pan bolt threads. Of course you'll have to wait until the Permatex cures before replacing the fluid.
raptor131's Avatar
raptor131
is it leaking onto the pavement or is it just seeping?
if it is leaking drips onto the pavement and all bolts are torqued to specs. you may have some foreign material between the mating surfaces, which would require complete removal of the fluid but you could save it. by using a clean container
Old Sep 11, 2009 | 12:40 PM
Stroked Out!
it is leak that i can see drip, overnight it left two puddles and it looks like from the rear of the pan
Old Sep 11, 2009 | 01:35 PM
69cj's Avatar
69cj
Did you use a torque wrench or the bygosh and bygolly method. If the latter, you could have tweeked the pan lip. Drop it, inspect and repair any deficiencies that you find. Then use a torque wrench.
Old Sep 11, 2009 | 05:32 PM
Stroked Out!
no i used the thats about- right- method. Whats a good way of truing it up?
Old Sep 11, 2009 | 05:35 PM
npccpartsman's Avatar
npccpartsman
Which gasket did you use to put your pan on?
Old Sep 11, 2009 | 05:40 PM
Stroked Out!
both the oem and then the one that was in the filter box wich is rubber, i also has one that is a sort of fiber one that i ahvent put on yet.
Old Sep 11, 2009 | 05:44 PM
npccpartsman
Use the OEM that was on there. It's completely reusable. I've had mine off twice and it's never leaked a drop (knock on wood). Valve cover gaskets are the same and I've reused them at least a dozen times with no leaks. Just DON"T over torque them.
Old Sep 11, 2009 | 05:57 PM
69cj's Avatar
69cj
Tim, he said that he used the "That's just about right method" could have bent the lip or crushed the gasket or both. Time for him to regroup and analyse things, do ya think?
Old Sep 11, 2009 | 06:23 PM
npccpartsman
Yup. Bein that it's friday night he just needs to and think about it, and if he did bend the pan then he can get the 08 pan and real filter and have something that works better.
Old Sep 11, 2009 | 10:39 PM
Stroked Out!
is the 08 pans deeper or what?
Old Sep 12, 2009 | 09:12 AM
69cj's Avatar
69cj
Their not bent! LOL
Old Sep 12, 2009 | 09:42 AM
npccpartsman
The 08 tranny's have a real transmission filter on them, not just the screen the earlier models have, but it requires a different pan, which happens to be deeper I believe. You can get both for about $120 or there abouts.
