red engine light
Old Sep 11, 2009 | 07:13 AM
roadking334's Avatar
roadking334
red engine light
I have a 89 model I am working on I6 5 speed . Was wondering what the red engine light on the dash ment? It burns all the time, The cel light is not on.
Old Sep 11, 2009 | 12:27 PM
Lazy K's Avatar
Lazy K
Either you have no oil pressure or the sensor is bad or the wiring to it is bad I would think.
Old Sep 11, 2009 | 12:28 PM
Virto's Avatar
Virto
Yep, the red light indicates no oil pressure.
Chances are since you haven't grenaded yet, that the sensor or wiring is bad. Have it checked with a mechanical gauge and then you know which direction to take.
Old Sep 11, 2009 | 12:45 PM
subford's Avatar
subford
It means that the engine is too hot or the oil pressure is too low.
You may also have a bad Engine Warning Indicator Module or something is unhooked.
Old Sep 11, 2009 | 02:16 PM
roadking334
Thanks for the info guys I will check it out this weekend .
Old Sep 14, 2009 | 12:18 PM
roadking334
thanks again guys, it was the plug on the back. had a bad contact
andrew's64
Apr 14, 2016 05:05 PM
skyking897
2004 - 2008 F150
16
Jan 30, 2013 02:52 AM
rbs62
Nov 22, 2011 08:56 PM
Fairlane62
1997 - 2003 F150
Apr 3, 2007 11:35 PM
fordman02
Aftermarket Products
Jun 6, 2002 06:22 PM
