Check engine light - trouble codes???
Old Sep 10, 2009 | 09:28 PM
90F250351's Avatar
90F250351
I had my 05 F250 6.0 scanned today for a check engine light. Came up with 2 codes...P0299 & P2290. Does anyone know what they mean and what would make them come on? They were cleared out and the check engine light hasnt come back on yet. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Old Sep 10, 2009 | 09:30 PM
devildog12210's Avatar
devildog12210
P0299 Turbo Underboost
P2290 Injector Control Pressure too low.
Old Sep 10, 2009 | 09:31 PM
jboczar's Avatar
jboczar
p0299 is a underboost/overboost code, p2290 is an icp circuit code. Have you had any power or boost issues? Or any hard starts or surging?
P2290 actually means icp was too low at some point during the drive cycle
Old Sep 10, 2009 | 09:38 PM
devildog12210
Injector Control Pressure = ICP
or so I thought...
Old Sep 10, 2009 | 09:44 PM
usmcmech's Avatar
usmcmech
turbo underboost = ****ty day. if you have a scan tool that will monitor pids check your vgt percentage. if it drops really low (below 35%) at WOT than you have a sticking turbo. then you have to take it off, seperate it and clean the hell out of it and make sure your unison ring is still good.
Old Sep 10, 2009 | 09:45 PM
90F250351's Avatar
90F250351
the truck just made a 3000 mile trip across country. could it have just been a 1 time malfunction or do you think i have a major problem? No hard starts or surging.
Old Sep 10, 2009 | 09:47 PM
90F250351's Avatar
90F250351
is this something that would be covered under the 100,000 mile powertrain warranty? my truck has 49k on it
Old Sep 10, 2009 | 09:54 PM
jboczar's Avatar
jboczar
Yes, take it in and let Ford pay for it. Of course you will have to tell them what codes you had since you had them erased.
Old Sep 10, 2009 | 10:05 PM
90F250351's Avatar
90F250351
Ok, thanks guys. I will bring it in tomorrow.
Old Nov 22, 2010 | 02:32 PM
airpilikia's Avatar
airpilikia
And another thread with no answer what happened at the dealer.
Old Nov 22, 2010 | 04:47 PM
rocky1074's Avatar
rocky1074
Found this on another thread by one of our FTE Techs m-chan68
A P0299 Turbo Underboost code can set by numerous causes, namely a leak on the intake side between the turbo, charge air cooler and intake, a biased or improperly functioning EBP sensor, a leak on the exhaust side between the exhaust manifold and turbo up-pipe to the turbo, a restricted exhaust or restricted (plugged up) intake and a stuck VGT unison ring. Now your job is to pinpoint which of the above is causing the code to set.
Old Nov 23, 2010 | 06:42 AM
cmssorrell's Avatar
cmssorrell
On the oasis report on my truck has the same trouble code and here is what was done to repair it........Replaced EGR valve and ran VPS test remove turbo and check vanes, vanes was stuck had to replace char on turbo and tested ok.
Have no idea what char means.
Mark
Old Nov 23, 2010 | 06:56 AM
npccpartsman's Avatar
npccpartsman
It should be CHRA--center housing rotating assembly or something very similar to that. Basically the center part of your turbo.
Old Nov 24, 2010 | 08:39 AM
cmssorrell's Avatar
cmssorrell
Thanks for the reply.
Mark
sddesigns
New Jersey Chapter
123
Aug 29, 2025 02:59 PM
Coupleofords
2009 - 2014 F150
16
Jan 4, 2016 08:02 AM
RA21925
23
Dec 7, 2013 11:44 PM
sddesigns
New Jersey Chapter
Apr 20, 2010 06:58 PM
THE BLUE HEAP
Dec 25, 2009 08:18 AM
