Guage question
Old Sep 11, 2009 | 08:02 PM
flamebuster's Avatar
flamebuster
Great pictures on the installation locations, that really helps, the previous owner of my truck must have had an egt. probe because there is a plug in the bottom of the drivers side exhaust manifold towards the rear of the engine, looks real easy to access it from underneath..Working on a building a console in front of the center console, to mount all my gauges and switches.... thanks for all the great information..Doug
Old Sep 12, 2009 | 07:11 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
If you have a coolant filter there's an extra port for ECT probe there. When Santa brings my ECT and FP gauges, that is where I'll be putting mine.( ECT that is)
Old Sep 12, 2009 | 01:31 PM
rayezra's Avatar
rayezra
What is this for
Hi first post. Thanks to all of you guys for being here and helping!
I recently bought my first f350 2004.
I am looking to put gauges on it and was looking at the pictures and looking at my truck. I found it has this screw right behind the turbo and I was wondering if it was for a gauge? See image:
Old Sep 12, 2009 | 01:43 PM
tex25025's Avatar
tex25025
More then likely that was for a post-turbo EGT gauge. About the only benefit from doing it after the turbo would be for a better turbo temp for shutting down the truck. Not the best place to get a reading for driving EGTs.
Old Sep 12, 2009 | 07:18 PM
flamebuster
First off welcome to FTE, and on your port I would be leary of the fact that there is a clamp over the plug, could be the threads are stripped or some other problem..just a thought.
Old Sep 12, 2009 | 08:34 PM
raptor131's Avatar
raptor131
I dunno. how else would you seal the hole cheap before you sell the truck . I would definitely take my guages out before i sold mne and that seems to be the easiest method of covering the hole
Old Sep 12, 2009 | 08:42 PM
flamebuster
I don't blame anyone for taking their gauges with them. But why wouldn't the plug stay in by itself if the threads are ok? Hence the clamp, ( if the plug can't stay in, then the sensor won't either.. jmo.
Old Sep 12, 2009 | 08:51 PM
william_04_x's Avatar
william_04_x
Twice i've blown a brass plug from my 6.0's exhaust manifold.. I guess they don't like the heat cycles.. The first time it was -20*.. I did the same thing with a hose clamp.. Thermocouples have stayed fine..
Old Sep 12, 2009 | 09:58 PM
flamebuster
Well that explains the clamp...my bad...lol..
SoCalAngler
32
Jan 1, 2016 12:25 PM
GeneGregory
Dec 20, 2015 10:22 AM
dhag911
Sep 13, 2014 11:49 AM
gDMJoe
2009 - 2014 F150
May 12, 2014 01:07 PM
southbound35west
Jan 12, 2007 02:09 PM
