New Mexico Chapter Join Chapter, Leader:
September ?
Old Sep 25, 2009 | 11:30 AM
KRDiesel's Avatar
KRDiesel
This is the clasic "stiction" issue, If it runs fine when warm the injectors are ok.
Make sure you are on the latest flash. run 5W40 oil, I recomend Rotella Syn.
And try hot shots. If it does not work he will refund your money!
Old Sep 25, 2009 | 02:18 PM
desertt5's Avatar
desertt5
Will look at it more then. Did not know they still did the refund part. Running dyno rotella right now. Got put in when other injector went out.
Old Sep 25, 2009 | 02:55 PM
KRDiesel's Avatar
KRDiesel
Go to synth rotella, that will help cold start
Old Sep 25, 2009 | 06:03 PM
desertt5's Avatar
desertt5
Originally Posted by santi2322
a C6 Tranny.. I have looked on Craigslist and haven't found anything. I need one for an FE motor, 2 wheel drive, going in a 1966. Hopefully one of you know where I can get one locally in alb or Rio Rancho.. Even Santa Fe would be fine. Thanks a lot.
Just saw this.
http://albuquerque.craigslist.org/pts/1392246505.html
No idea if that's expensive or not. Seems like it could be. I am guessing all C6's are the same ??
Old Sep 25, 2009 | 06:11 PM
desertt5's Avatar
desertt5
Planned on going synthetic, but haven't put enough miles on it to rate an oil change. It is breaking too much to drive !!!
I will eventually win and it WILL run right soon....... I hope soon
Old Sep 28, 2009 | 12:30 PM
KRDiesel's Avatar
KRDiesel
Hey, It's monday!!
Old Sep 28, 2009 | 05:18 PM
F0rdFre@K's Avatar
F0rdFre@K
Originally Posted by desertt5
Just saw this.
TRANNY C6 2WD REBUILT BY UT
The internal workings of a C6 are all the same. This one being behind a 351M makes it a "Big Block" tranny. Being that it's recently rebuilt. $750 isn't too bad.
It will NOT work if you plan to put this behind a 351W or 351C. Just so you know. And $500 for a 351M is a bit much since they aren't all that desireable engines. But, you can put it behind a 460 and have a .
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
