Does not run when cold
Old Sep 8, 2009 | 10:04 PM
patofdoom's Avatar
patofdoom
i have a 92 f-150 with a 5.0 and when i start it in the morning it starts normally for about 3 seconds then the idle drops and if i don't give it some gas it will die, after letting it run for about a minute it will run normally but the check engine light comes on but if i give it some gas the light goes off, if i stop giving it gas the light will come back on. After i drive it for about 15 minutes it stops and runs fine.
Old Sep 8, 2009 | 10:42 PM
393STROKER's Avatar
393STROKER
The first thing they always say is check the codes.My `90 had some of those symptoms and the altenator was not putting out enough juice.
Old Sep 16, 2009 | 05:52 PM
patofdoom's Avatar
patofdoom
i pulled the codes on the truck and said that it had low voltage to the throttle position sensor.
Old Sep 16, 2009 | 07:42 PM
Boss F150's Avatar
Boss F150
Had a similar issue on my '93 with the 5.8 last winter. New TPS fixed the issue. Do yourself a favor and get a Motorcraft TPS, found mine on ebay for about $35 delivered.
Old Sep 25, 2009 | 02:28 PM
patofdoom's Avatar
patofdoom
I replaced the throttle position sensor and that took care of the problem. Thanks for the help
