Sponsored by: Real Truck
Rear end bounce
Old Sep 7, 2009 | 07:58 PM
mitchntx's Avatar
mitchntx
Rear end bounce
After I installed the 18" Michelin AT2s LTs, I have been getting a harmonic "bounce" in the rear of my 07 PSD SD CC.
It occurs at about 45 mph and seems to initiate when I hit a small bump in the roadway. Consequently, it doesn't happen all the time.
When it does occur, a little bit of gas or a little bit of brake makes it go away.
Air pressures doesn't seem to affect it. Anything from 65psi to 80 psi sees the same result.
I have new Bilstein HDs on the truck.
It doesn't feel like a balance issue.
I inspected the driveline and didn't see anything loose or any evidence of it shaking.
I took it back to NTB hoping to get a balance check and tire rotation to attempt to move or eliminate the problem.
But the "mechanic" was convinced that it was a warped rotors without ever looking at the truck much less driving it. I've felt the "shake" feedback that warped rotors gives. This is a bounce, like you feel with a cab-over, short wheel base tractor with no trailer attached and you tap the brakes.
After all that, anyone have any suggestions on where to look to solve this problem?
Old Sep 7, 2009 | 10:15 PM
EXv10's Avatar
EXv10
I would switch the the wheels around first.
F250_JR
23
Oct 30, 2018 10:02 AM
97powersmoke
May 13, 2014 04:30 PM
druggles85
1997 - 2003 F150
Sep 20, 2009 05:50 PM
THEDON117
Mar 24, 2009 12:08 AM
MTMike
Aug 27, 2004 10:36 AM
