2004 ford f150 help
Old Sep 7, 2009 | 12:20 AM
littlewagner's Avatar
littlewagner
2004 ford f150 help
hello everyone i have 2004 ford f150 super crew with the 5.4 latly I have been noticing occasionaly at take off from like stop signs an stuff it almost seems like my truck slips then grabs. it will like grab real hard. whenever im at take off from stop sign or lights or whatever. but its not all the time an it seems like when im easily accelerating not just putting it to the floor. also second thing is occasionaly when i am traveling down the hwy i get a vibration in my foot pedal when slowly getting on the throttle over 40 miles an hour. this problem happens occasionaly also. in a way i get a little vibration an it sounds as if a noise is coming from the motor like vibration but im not sure on the placment of the noise. for all i know it could be coming from underneith the truck. thank you for taking your time an reading my problem. its kind of poorly worded but hope you can help. i rather do it myself than take it in but if noone can help i will just take it in thanks.
Old Sep 7, 2009 | 09:22 AM
2000 roadking's Avatar
2000 roadking
sounds like several things could be going on. if no codes ,..could get very expensive just guessing. Keep reading in this forum you might see someone with your same problem or find some link to more info. there a lot of stuff going on in here. good luck.
Old Sep 7, 2009 | 02:10 PM
fordman19762003's Avatar
fordman19762003
it could be from the slip yoke on the rear driveshaft being a little dry or maybe you have a bad u joint.
Jeff396
Jul 22, 2012 09:20 PM
Baer
1997 - 2003 F150
May 17, 2012 09:47 PM
nothercrash
Jan 18, 2010 07:46 PM
elemint
Apr 7, 2006 08:18 AM
Phil123
Electrical Systems/Wiring
Jul 11, 2003 05:46 AM
