I've got a 94' ranger 4.0 4x4 with 112k miles on it. My gas mileage isn't great. I'm sure many of you can relate. Can some of you guys throw out what you typically get? Just wanted to see how I compared to someone with similar year and mileage.
I'm getting over 20 per gallon. Obama suggest that you keep your tire pressure up to increase gas mileage, this can decrease our dependence on foreign oil imports and decrease our trade deficit, Then I laughed.
I've got a 1999 ranger 3.0L flex-fuel v6 automatic 4R44E.
I did tranny fluid changes (drain) every 30k including a filter change. Just had the tranny flushed out completely (including a full torque converter flush) two weeks ago and didn't have any crude or metallic bits in the pan. The fluid was varnished, but mostly due to the heat caused by a failing water pump not helping to keep the fluid cool and the contributor to causing the running hot condition. I do have the add on trans. fluid cooler. Other than that, the total flushed improved the tranny performance. For nearly 160,000 miles, I'm impressed with the original tranny, still holding on strong.
I have a '99 Ranger XLT, extended cab, 4WD, 3.0 Flex Fuel motor with the automatic. I average about 21-22MPG on the highway from April to October. I usually get like 16-18MPG in mixed city and short trip driving.
