Sponsored by: Auxito
Compatible?
Old Sep 6, 2009 | 09:23 PM
Built_Ford_Tough_757's Avatar
Compatible?
My dad found a transmision and transfer case in the trading post. We wonder though if it would work because the truck it is out of has the 4.6 V8 while mine is a 5.4 V8. Its for $100. Thanks
Old Sep 7, 2009 | 02:01 PM
LxMan1's Avatar
LxMan1
The 4.6L uses a higher stall speed torque converter, but the rest should be the same as long as you have a 4R70W trans now (should be).
Old Sep 14, 2009 | 01:59 PM
jas88's Avatar
jas88
The 5.4L is backed by the 4R100 (E4OD), not the 4R70W (AODE).
Old Sep 14, 2009 | 05:20 PM
papajoemrt's Avatar
papajoemrt
Like Lxman said the difference is in the torque converters. If the transmissions are the same then you will be fine. Check the sticker on each truck to see if the transmission codes are the same.
Old Sep 14, 2009 | 09:28 PM
DJPRacer58's Avatar
DJPRacer58
if your workin on the 98 in your footer then no the tranys are different
