Copper RTV
Old Sep 8, 2009 | 04:16 AM
jowilker's Avatar
jowilker
Looks as the consensus is added to gaskets but used in place of, correct??
John
Old Sep 8, 2009 | 10:23 AM
Barry_R's Avatar
Barry_R
I use a really thin layer of copper RTV - like a coat of paint - on Fel-Pro header gaskets. Seems to work quite well - even on the dyno under serious load.
Old Sep 8, 2009 | 12:45 PM
jowilker's Avatar
jowilker
Thanks, I have bought my share of gaskets for that engine with starter failure and valve issues in about 11 years now.
Makes no difference that the Felpro 375-142 has extra holes?????
John
Old Sep 9, 2009 | 09:27 AM
scottfreeman's Avatar
scottfreeman
copper rtv
I have used copper rtv on my headers for about 15 years. They seal up good and the silicone does not get brittle. It is messy to clean up, but how often does one take headers off of a daily driver? I also use it for intake gaskets and pan gaskets and such. works better than the regular rtv.
Old Sep 9, 2009 | 09:58 AM
yellow truck's Avatar
yellow truck
How exactly did you you use Copper RTV
Barry and Scott - I am going to have to install my 410 with headers this weekend, and I had bad leaks on the 360 I pulled (with the same headers). What would be very useful is if you described the procedure you followed.
Barry - you said you used it with a Fel Pro gasket. Did you follow the usual process of torquing them and then heating the engine and re-troquing?
Scott - sounds like you just used the Copper RVT. Is that the case, and if so, do you follow the same procedure you would if a gasket was present?
We need details!
Old Sep 9, 2009 | 10:14 AM
scottfreeman
procedure
We need details!
I used gaskets, coated on both sides. I finger tightened the bolts and let the rtv set up for about 15 minutes or so. Then I tightened them down. I know, I should torque them, but I don't on headers for some reason. I also use it on the collectors on both sides of the gasket.
Old Sep 10, 2009 | 09:00 PM
hiball3985's Avatar
hiball3985
For what it's worth, I've used REMFLEX gaskets with nothing but good results.. No goop needed
http://remflex.com/
Old Sep 10, 2009 | 09:12 PM
Kennewick's Avatar
Kennewick
We need details!
The RTV says tourque once doesn't need retorque
Old Sep 10, 2009 | 11:26 PM
tbm3fan's Avatar
tbm3fan
Originally Posted by Kennewick
Hi John. I just used the Copper RTV on my stock manifolds and it is still setting up. I will fire it up tonight. It is very thick and I liked the application. I have a thread ""exhaust mainfold improvement"". I will let you know.
The jerks at the auto stores act like it is from mars. I asked an application question and was berated for being a stupid idiot. " You can't use RTV on exhaust manifolds, come on buddy" then I asked him to read the package "For exhaust manifolds" then he says " no real mechanic uses that crap" As I started for the door I said "must be why your working here" I think its good stuff but tonight I will light er up.
I did this 2 1/2 years ago after I had the stock manifolds milled flat. Used the copper RTV as someone suggested, think it was the place that milled them, and it has run fine ever since...
Old Sep 12, 2009 | 02:22 AM
tomcasino's Avatar
tomcasino
On my 390 with stock manifolds the gaskets kept leaking. I tried the factory style with the metal on one side and also the paper ones. They all leaked. The Mr. Gasket copper gaskets with Grade 8 bolts and copper anti-seize on the bolt threads worked without any leaks. I now have Hooker headers and they have special gaskets. No leaks. I have used all different colors of RTV on gaskets but never on the exhaust manifolds.
Old Sep 12, 2009 | 08:16 AM
Barry_R's Avatar
Barry_R
I just put a THIN layer of RTV around each port and hand tighten the fasteners. After the engine runs I go back around and retighten again.
Old Sep 12, 2009 | 09:24 AM
cparks's Avatar
cparks
When we used to run the old style thin flange headers we used to go through header gaskets on our 390 fairly often. We started using the copper RTV on the header side only and it made them hold in place and last much longer.
hail destroyer
Sep 28, 2016 08:33 PM
hail destroyer
Sep 28, 2016 08:26 PM
deerhuntertyler
Jan 6, 2016 11:18 PM
'94IDITurbo7.3
25
Mar 16, 2012 12:36 PM
ceetwarrior
Nov 9, 2009 09:07 AM
