Sponsored by: Real Truck
Factory radio replacement ?
Old Sep 5, 2009 | 01:31 PM
rlivin's Avatar
rlivin
I have a 2000 f250 with factory cd player and wanting to upgrade to a later model with 6 disc and mp3 capabilities. Say a 2008 model. i assume the plugs may be different but other than that will they swap out? TIA
Old Sep 5, 2009 | 01:42 PM
TexasRebel's Avatar
TexasRebel
2000
2008
No
Old Sep 5, 2009 | 01:52 PM
rlivin's Avatar
rlivin
is there any that will swap that has 6 disc and mp3? if so what model? i realize i may have to modify dash or use adapters, thats no problem.
Thanks
Old Sep 5, 2009 | 01:58 PM
TexasRebel's Avatar
TexasRebel
I'm not sure you'll find an OEM that is swapable with those.
When the MP3 capability came out, Ford had gone away from the locking mechanism that was used in 2000. At some point they realized how easy it was to lift those radios if you had the removal pins.
That radio will come out and disappear less than 10 seconds after the window is busted or the lock is popped.
Old Sep 5, 2009 | 08:25 PM
1975StroppeBaja's Avatar
1975StroppeBaja
Thanks
Yep! You can find them if you keep an eye on ebay. I got one from a 2006 Escape -- CD6/MP3 with the correct plug on the back and the correct mounting config...
Here's some info I put up about my swap...
http://www.frontiernet.net/~jmray/F250Stereo.htm
bayoudawg
Jun 6, 2017 01:53 PM
Scrpmny
Nov 22, 2016 05:14 AM
jake00
2015 - 2020 F150
16
Mar 7, 2016 12:32 PM
Kylebb
2015 + Expedition & Navigator
Jan 9, 2016 05:22 PM
Duksrule
Dec 20, 2010 06:47 PM
