Recorded DVDs won't play?
Old Feb 13, 2008 | 06:44 AM
Duksrule's Avatar
Duksrule
I have an 03 Excursion with the factory DVD player in the back. It won't play DVDs that have been recorded. I am wondering if maybe the newer model trucks do or if someone has found a aftermarket DVD player that will swap into the factory spot?
Old Feb 13, 2008 | 07:57 AM
vettdvr's Avatar
vettdvr
Probably the incorrect format for music. If you do a disc to disc copy it might work but if you copy each song to the disc you might have an incorrect format. I have experienced this also,, but haven't made another disc.
Old Feb 13, 2008 | 08:22 AM
Duksrule's Avatar
Duksrule
I'm talking about the DVD player that is in the back. I can play burned CDs in the dash. I just can't play burned or copied DVDs in the factory player in the back seat.
Old Feb 13, 2008 | 09:41 AM
ukmat71's Avatar
ukmat71
what format are you using most car dvd players will use dvd-r but not dvd+r
dont ask me what the difference is as i dont know.
I use dvd-r here with no problems
Old Feb 13, 2008 | 09:47 AM
Duksrule's Avatar
Duksrule
I tried a -R +R and even an R/W but none work. An actual original DVD plays fine. Wondering if in later years they changed to an updated player
Old Feb 13, 2008 | 10:04 AM
Magilla_v6.0's Avatar
Magilla_v6.0
I don't think so, my 04 won't play recorded DVD's either.
Old Feb 13, 2008 | 10:31 AM
ukmat71's Avatar
ukmat71
could it just be the brand of disc , i use DATAWRITE , not sure why i said that as you probably cant get them in the States.
Have you checked to see if there is a firmware update for the dvd player. i know you can sometimes e-mail the maker telling them of your problem & if there is an update you can burn it to a cd-r & put it in the player , turn it on & it does it all for you.
might be worth e-mailing Fords , nothing to loose
Old Feb 13, 2008 | 01:06 PM
firehog47's Avatar
firehog47
Marcus may have hit the nail on the head, try a DVD-R, if that won't play then the player is not capable of playing any aftermarket dvd's. Generally the player is marked with supported formats. dvd-r and dvd+r are diff... formats and most players designed for aftermarket dvd's are designated to the dvd-r format.
Old Feb 13, 2008 | 02:09 PM
rcracerx's Avatar
rcracerx
MY 04 wont play anything but a factory pressed DVD.
Carl
Old Feb 13, 2008 | 03:01 PM
quietman's Avatar
quietman
I had some of these troubles back in late 2004 when I bought
my rig. With 5 young kids I HAD to find a solution.
What worked for me was to buy a stand-alone independent
DVD/CD burner. It plugs into the wall and a USB port on my computer,
and makes better copies than the internal burners that came with
my computers.
I also use only (-) disks, after researching this.
I have had zero problems since...
Quietman
www.roenation.com
2005 EXCURSION- options (everything) equipped Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein $$ mono-gas shocks, Rancho Steering Stabilizer
Silverstar 9005 fog and H13ST headlights + wiring mod to run high beam and fogs together,
BFG 315/75/16 AT KO's on Factory Mags, 22" front and 18" rear rain-x wipers, Auto
-zone aftermarket voltage gauge, LANDYOT Generation II Radius Rods,
Ford factory hood insulator, Mojave Pin-Striping
Old Feb 13, 2008 | 04:02 PM
VaSheriff's Avatar
VaSheriff
I suspect it's CODEC related. The OEM system may not be able to read what you are writing to the disks.
See..... http://netforbeginners.about.com/od/...ia/f/codec.htm
Old Dec 20, 2010 | 02:20 PM
1NiceHarley's Avatar
1NiceHarley
Old thread Yes. Anyone came up with a solution? we can't play recorded DVDs in our Ex either.
Old Dec 20, 2010 | 02:32 PM
ukmat71's Avatar
ukmat71
sounds silly but when you record (or copy , illegal of course but we all do it) you have got the region code correct , ie region 1 for the us , region 2 for the uk etc etc.
on my software i use , i copy them without a region code , so it will play anywhere.
i would imagine your default settings are region 1 and NTSC as default , but you may be recording them as region 2 and Pal output.
only a few seconds to check , may make a difference
can you play cdr's , ie the old avi video ? ok on cd's ?
but it may just be down to the manufacturer and the colour of the dye they use in the disc, some will read , some wont.
trial and error works eventually.
ask to see what type people use that work and go from there.
Marcus
Old Dec 20, 2010 | 02:46 PM
Rickx's Avatar
Rickx
It may be the age of the original DVD. We have DRM to contend with now also. That's Digital Rights Management. Some DVDs can't be copied. Can you play your copied disk on another player, if so this isn't the case.
Old Dec 20, 2010 | 02:54 PM
ukmat71's Avatar
ukmat71
everything can be copied , why do you think they introduced DRM ?
macrovision for example bypassed within a few hours by a teenager lol
you just tell your computer in a sort of strange way that you own the rights , in fact you do have the right to copy/back up your own dvd's , music , blu-ray etc
anyone heared of clonedvd btw ?? anydvd ?? Elaborate Bytes ??
google them as i know the links wont be allowed here. but really easy , like 123 abc.
i think its down to the type of disc being used. some will ,some wont work
