Power steering help
Old Sep 5, 2009 | 10:19 AM
Hunters's Avatar
Hunters
Power steering help
I've got a 96 Explorer that has a shake or studder in the steering when turning. I've checked the fluid and it is ok, drive belt is ok, there are no fluid leaks. Can anyone tell me what is causing this? I'm just guessing that it is the PS pump?
Thanks! <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Sep 5, 2009 | 01:38 PM
aquanaut20's Avatar
aquanaut20
If you have turned the steering with the engine off, you have induced air into the steering cylinder.
Turn lock to lock a cple of time with the engine running will expel air, also check fluid level.
Might be an idea to flush the P/S system if it hasn't been done already.
sddesigns
New Jersey Chapter
123
Aug 29, 2025 02:59 PM
jabro
Jan 19, 2016 03:55 AM
Coupleofords
2009 - 2014 F150
16
Jan 4, 2016 08:02 AM
mno3fan
Modular V8 (4.6L, 5.4L)
Mar 1, 2013 12:39 PM
firecatab
Computer Chips & Tuners
Jan 20, 2010 06:52 AM
