injector test
Old Sep 4, 2009 | 10:34 PM
arkredneck's Avatar
arkredneck
injector test
is they any way to test to see if a injector is working without a scan tool is there like a redneck way you can do it?? anyway to listen to each one with a pipe or something?? can you take off the valve covers and pull the electrical connector one by one while it's running?
Old Sep 5, 2009 | 05:40 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
If you have a miss at idle, that's exactly what you can do. You will not spray oil all over, unless you rev the motor w/o the vc on. It can sit an idle all day and not get oil over everything so don't worry about that. It's best to pull the plug right at the injector and not 'rock' the plug loose outside the vc.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 5, 2009 | 09:08 AM
arkredneck's Avatar
arkredneck
so if an injector is firing at idle is it possible for it to miss when the engine is reved?? and what would cause it do that
