low oil pressure????
Old Sep 3, 2009 | 08:30 AM
cornbinder's Avatar
cornbinder
my 95 has low oil pressure and can't figure out why?? carries 0-2 lbs at an idle and maybe up to 10 lbs at 1500-1700 rpms, 2500 rpms its around 20-25 psi. the engine doesn't knock ar make any unusual sounds or anything. i'm nevous though that i'm gonna drive it down the road and parts are gonna fly. anybody else ever had this problem before? any help would be appreciated.
Old Sep 3, 2009 | 10:09 AM
Talyn's Avatar
Talyn
On top of the HPOP, there is a little elbow connector on a post. It's small and on the left side of it when looking from the front. Pull that thing off and clean it. I had to pinch mine with pliers to keep it from acting up. I don't think it is a really accurate gauge, but it lets me know my HPOP is low at start up. haha.
You didn't say if you had a different gauge, so I'm assuming your talking about the stock one.
Old Sep 3, 2009 | 11:01 AM
Neal 97 250's Avatar
Neal 97 250
What gauge are you using?
Where are you taking your reading from, where on your motor?
Old Sep 3, 2009 | 03:31 PM
Cuda_jim's Avatar
Cuda_jim
Have you checked the oil filter bypass valve I mentioned in your other post?
https://www.ford-trucks.com/forums/8...-readings.html
Old Sep 5, 2009 | 06:46 AM
cornbinder's Avatar
cornbinder
i checked pressure from a little plug ttthat threaded out down buy the oil filter with a manual gauge.. no i didn't check the bypass valve yet. you sure that'll cause low pressure?
Old Sep 5, 2009 | 10:00 AM
rodneywar's Avatar
rodneywar
I am curious where exactly are you supposed to check the oil pressure. I would like to check mine. Thanks
