No Start, No Fuel
Old Sep 4, 2009 | 08:31 PM
NavFlyer's Avatar
NavFlyer
No Start, No Fuel
I just wanted check onboard with the gurus just to make sure all my bases are checked. I have a '92 F150 4 X 4, all stock. The other day I pulled into the gas station to put gas in my rear tank. I always cycle my tanks, but can never afford and have little reason to fill both. Any way, I hopped back in and the truck just cranked over without starting. Just to be sure I cycled to my front tank, and still no start. I checked the rail and no fuel was present on the valve and I cannot hear either pump. Next I checked the relay. I didn't have a meter handy, so I swapped with another relay and still did not start. To confirm fuel pump operation, I went ahead and grounded out the pin and listened for the pump. The pump worked and put fuel back up to the rail. I have even checked the inertia switch and all seems fine. Amy I correct to assume the EEC is bad? I mean, is ther anything else that I may have overlooked? Anyways, thanks for reading and all help is appreciated.
Old Sep 5, 2009 | 01:37 AM
kc0rey's Avatar
kc0rey
Check all the wires going to the relay socket. I have seen these go bad several times. The relay for the EEC may be bad or the wires for it as well.
I've seen the wires separate due to corrosion right at the crimped on connector. Just give them a light tug. If one is bad it will come out in your hand.
Old Sep 5, 2009 | 07:10 AM
subford's Avatar
subford
If you grounded pin #6 of the EEC Self-Test plug with the key on and the pumps ran as I think that is what you said. Then the EEC (PCM) power relay and the Fuel pump relay and their wiring are OK.
Make sure you have power to pin #'s 1, 37 & 57 on the computer with the key on and pin #'s 40 & 60 have a good ground.
Also check to make sure Computer pin # 22 has continuity to pin #6 of the EEC Self-Test plug.
Check to make sure all pins look OK and not pushed out in the computer plug.
If all checks OK and the pimps still do not come on for the one second time out when you turn on the key them yes you may have a bad computer.
Old Sep 5, 2009 | 09:42 AM
kc0rey's Avatar
kc0rey
WOW! Can I call you the next time my truck won't start? That's a bunch of good info!
Old Sep 5, 2009 | 05:17 PM
NavFlyer's Avatar
NavFlyer
Yeah, I was sure to check ALL of the wiring. I noticed some moisture on the computer connector and pins 57 - 60 were corroded, there were others, but those were the worst. I just don't think there is anywhere else to look and just wanted to check.
Old Sep 12, 2009 | 10:57 AM
NavFlyer's Avatar
NavFlyer
Good Morning All, I had to do a little searching to find my post. I dug up some of my previous posts and learned an interesting thing. I, like most, tend to approach the board to gain knowledge on a problem that I am experiencing. In short I never really posted my overall results and contribute to what makes this forum so great. My deapest apologies. Today, I decided to brake that trend. On Wednesday my reman computer was delivered. (Yay $100) I cleaned the connector and sprayed some electrical grade water displacing compound and reseated the connector. My truck has never ran better. It even shifts better. If I had any idea that my computer had contributed to so many deficiencies, as to the performance of my truck, I would have replaced it a long tim ago. I just accepted the fact that she was getting old. It is like she just receive an injection of youth. Thanks, to all that have helped, you posts really make this forum work.
Good day,
NavFlyer
Old Sep 12, 2009 | 02:06 PM
kc0rey's Avatar
kc0rey
Good job, Good post and thanks for the update.
I wonder how many problems can be resolved by cleaning, or repairing wires. I'll bet a bunch. I'll bet even more parts get sold because of it.
Again, Good job!
Old Sep 12, 2009 | 02:19 PM
NavFlyer's Avatar
NavFlyer
You are 100% right. A little bit of water intrusion had taken place, but I could have saved my computer if I would have performed regular cleanings beneath the connector. We rely too much on the "not broke, don't fix it", but when you think about it, a little preventative maintenance could go a very long way.
Old Sep 12, 2009 | 02:25 PM
subford's Avatar
subford
Make sure you put dielectric grease in the plug to keep water out also.
