steering and suspension
Old Sep 4, 2009 | 04:46 PM
roadrash63's Avatar
roadrash63
hi
its been along time since i drove a truck this old 85 f150 ( 302 fi m19trans 4x4) 55 is circled on the speedo !
but i just got insp so im legal now....had center link , tie rods and new shocks put on. but seems steering is still loose apx 1/8 of steering wheel.
i want to tighten it and the front suspension up ....any help pls
ps : my 14 yearold girl went for the first ride in it since i saved from the "woods" said " dad this thing is a little scary" (as i shifted into third with a brand new clutch) i then explained to her that this was a real truck not like my 2000 ranger 3.0 auto...
Old Sep 4, 2009 | 05:56 PM
Alcaeus's Avatar
Alcaeus
from my thread
Originally Posted by newrider3
My truck had a bunch of play in the steering too, the same setup as yours. You just need to tighten the sector adjustment shaft. If you have a repair manual for the truck, it tells you what to do in the steering section.
Might be your problem?
Old Sep 4, 2009 | 06:55 PM
roadrash63's Avatar
roadrash63
sector adjustment shaft ?
ok
whats the sector adjustment shaft?
is on the steering box ?
Old Sep 4, 2009 | 07:32 PM
Alcaeus's Avatar
Alcaeus
What the box looks like
http://www.stangerssite.com/HowItWorksSteeringBox.html
How to adjust
http://www.stangerssite.com/adjustment.html
Old Sep 4, 2009 | 07:36 PM
Ken Blythen's Avatar
Ken Blythen
It's the screw adjustment with a locknut on it, on top of the steering box as you look down on it.
If it needed adjusting, it makes a big difference to steering & handling.
But there's a proper procedure, as newrider3 mentioned.
If over-tightened the steering gear wears.
Old Sep 4, 2009 | 08:31 PM
roadrash63's Avatar
roadrash63
suspension stiffening front
hey
thanks for the info on the steering box.
what about stiffening front suspension up?
Old Sep 5, 2009 | 03:01 PM
muleguitar's Avatar
muleguitar
you can get a set of new coil springs from autozone or checker for like 70 bucks
Old Sep 6, 2009 | 08:57 PM
Built_Ford_Tough_757's Avatar
If you lift it, you would need an alignment. Which for my '85 was $140 and not done right. I need to have someone else do it. I almost can't keep mine in the paint.
