Motor Problems.
Old Sep 4, 2009 | 01:59 PM
zpmps2's Avatar
zpmps2
Motor Problems.
Hi all, got kind of a bad situation. First off its the 80 4x4 in my sig.1. Been down for probably a year and a half now just sitting in the front yard and have had major problems wrong with it. We worked on it three days ago and it kinda stumbled tried to start. So we unhooked the fuel line BEFORE the fuel filter right as it goes into the carb. No fuel is coming out. So me and my dad put together maybe the mechanical fuel pump. Changed that out still no fuel. Took the cap off of the distributor and noticed it was not spinning on the inside. Pulled the dist. and it spins when you turn the gear on the bottom. Put it back in turned motor over and still didnt spin. 2. So i'm thinking maybe the timing chain is broke but never really heard of that happening? Today I'm going to take the valve covers off to see if the rockers will move or not to narrow it down. 3. The motor turns over just fine. No weird noises or rattling or nothing.That leads me to what ya'll think it is!? I'm thinking putting the 300-6 from my F-100 into it rebuilding the 351M and hot rodding my 2x4 around. But thats if the motor is totally toast. It has always ran like a top no problems.Please help me guys sorry for the long post but it was needed to get all the reasons out to you.Thanks, Taylor
Old Sep 4, 2009 | 02:03 PM
zpmps2's Avatar
zpmps2
Forgot to mention that maybe the gear that turns the distributor from the camshaft is stripped? Whats the possibility of that. Any help ya'll can give will be used and appreciated!Taylor
Old Sep 4, 2009 | 02:07 PM
Mustang6147's Avatar
Mustang6147
Sounds like you timeing chain broke, I doubt very much if you valves are gonna move, but you better check, to rule it out... Did you look in the dist hole, and visualize the gear?... (inspect)
As far as the fuel issue goes... You can try to put air into the fuel line, first loosen the cap on the tank.. That way if there is any debri stick to the pick up, it will move it away... The rubber diaphram probably dry rotted in the old pump... I am a big fan if capping off the mechanical pumps hole, and putting an electric one back by the tank...
Old Sep 4, 2009 | 02:09 PM
Mustang6147
We were typing at the same time...
Old Sep 4, 2009 | 02:13 PM
zpmps2's Avatar
zpmps2
[quote=Mustang6147;7901278] Did you look in the dist hole, and visualize the gear?... (inspect)
quote] Yes I did, but I could not look pass the little spacer looking thing?? Dont know what its called and didnt see anything. Didnt have a flash light either, but would their not be any weird noises if the timing chain broke?? Even when it turns over?
Old Sep 4, 2009 | 03:16 PM
Ken Blythen's Avatar
Ken Blythen
If the timing chain is broken, you won't get any fuel delivery because the pump is driven off the camshaft
Old Sep 4, 2009 | 03:32 PM
Mustang6147
I agree... I think his timeing chain is broken.
Old Sep 4, 2009 | 03:42 PM
lew52's Avatar
lew52
If your distributor gear looks good then its probabley the chain , X 2 on the fuel pump , cam dosn,t turn no fuel... Lew
Old Sep 4, 2009 | 09:05 PM
zpmps2's Avatar
zpmps2
The distributor gear looks as good as it can possibly get.
And of course the haynes manuel just says how to check tension, doesn't tell you how to get it off. So my next question is how in the world do you get to it. Already taken the fan, harmonic balancer, grill and radiator out, and the 2 belts off, now just waitin for some input.
Thanks guys.
Taylor
Old Sep 4, 2009 | 09:23 PM
Mustang6147
Did you take the valvecover off, and rotate the engine, to see if the valves are moving...
Old Sep 4, 2009 | 09:44 PM
jeramy's Avatar
jeramy
pull the timing cover. might have to drop oil pan too can't remember.cam gear bolts to end of cam and crank gear slides/is pressed on to end of crank and held in time by key way(short square rod inserted in grove.) timing chain is run around the outside of both of these make sure to set engine to top dead center number 1 cylinder install crank gear with alignment dot straight up.wrap the chain under it and over the cam gear then bolt cam gear to cam making sure to align the timing marks on the crank and cam gears with each other while installing.
generic pic. 351w i think should still be same process for all ohv v8 engines
Old Sep 4, 2009 | 09:50 PM
Mustang6147
What happens if he pulls the timing cover, and the chain aint broke... Then should he rotate the engine???
A little humor, thats all
Old Sep 4, 2009 | 09:54 PM
jeramy's Avatar
jeramy
if chain isn't broke i would crank it over to see what ain't spinning.
Old Sep 4, 2009 | 09:55 PM
Jmeyer1990's Avatar
Jmeyer1990
no, in that case. break it. and replace it :P
Old Sep 4, 2009 | 09:57 PM
jeramy's Avatar
jeramy
good point if he goes that far in might as well replace it anyways cheap insurance
