Hpx?
Old Sep 4, 2009 | 07:24 AM
HD Rider's Avatar
HD Rider
Hpx?
Is the HPX mod worth it, or a waist of money?
Old Sep 4, 2009 | 07:31 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
youre gonna get different opinions on this but i am one that likes it. smooths out the idle and quiets her down a bit.........
Old Sep 4, 2009 | 07:37 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I have it also, and I think there is a benefit to have it on. If it is a waste of money, it ain't a lot of money. lol.
Old Sep 4, 2009 | 07:44 AM
mueckster's Avatar
mueckster
I took mine off when I installed the Stealth HPOP, but I did notice a difference without it. I'm probably going to put it back on when I get my new O-rings.
Old Sep 4, 2009 | 07:45 AM
03_PSD's Avatar
03_PSD
I think its a good mod.
Old Sep 4, 2009 | 07:46 AM
riverrat41's Avatar
riverrat41
I have one on mine.No seat of the pants difference but most of the gurus here recommend them to get more oil to #8
Old Sep 4, 2009 | 09:04 AM
agg_bagg's Avatar
agg_bagg
like barry said, even if you don't notice any difference with sound or power it will help supply the #8 injector with more oil. and that is always a good thing.
Old Sep 4, 2009 | 09:09 AM
binuya's Avatar
binuya
I just put one on about 75 miles ago. Now that the air's been worked out of it, I'm noticing a slightly smoother idle.
My primary reason for installing it though, since I prefer to run Delo 400 15w40, was to hopefully alleviate the occasional idle romps in the winter.
Old Sep 4, 2009 | 10:19 AM
Stroked99's Avatar
Stroked99
I would recommend it the HPx. If you don't have the cash for a new pump this would be a highly recommend option. The biggest issue is the pressure to the #8 injector. This balances the pressure. I would recommend speaking to Clay at Riffraff Performance. He has the option of the hardline and the softline for the crossover. Here is a link at his website for the hardline:
http://www.riffraffdiesel.com/mm5/me...egory_Code=new
Old Sep 4, 2009 | 11:04 AM
danskool's Avatar
danskool
Go Bills !
I had the nasty romp. SO i thought the HPX would help that. Didn't. And i didn't notice any different in throttle response/injector clatter or anything. SO i was kind of disappointed. But if these folks say it helps the #8 then it was worth it to me.
SYN oil and one dead glow plug got rid of my romps.
My dad don't have the HPX. and the trucks sound identical.
My CCK cured my squacky cackle though. Dad don't have the cackle or the cck either. His purrs like a kitten as is. Wierd. I like comparing with his truck to mine. They are nearly identical. His 2000/mine 2001. Like he don't have the LL injector. Mine did untill recently i swapped mine out.
Old Sep 4, 2009 | 08:38 PM
MTDewX's Avatar
MTDewX
I put mine on and really forgot about it. I will be taking it off since I will be installing a new HPOP (adreniline from Deiselsite) guess its not needed any more.
did I notice much? not really, but I also run VO so that last cyclinder gets plenty of oil cause that is where I inject my VO when on it.
at least its one of the cheaper modes
Old Sep 4, 2009 | 10:04 PM
indyF-350psd
i took mine out per bob's instructions and ended up putting it back in to resmooth the idle back out............
Old Sep 5, 2009 | 08:18 AM
HD Rider's Avatar
HD Rider
Thanks guys. Guess I'll get one.
