Basic warrenty question
Old Sep 3, 2009 | 09:23 PM
FordMan35's Avatar
FordMan35
I just have a couple of quick questions on the 6.0l warrenty. Is the 5 year 100,000 mile warrenty on the motor standard, and if so how many times can it be transfered. I am the 4th owner of my truck and the warrenty period started 6/21/2005. I have 84000 miles on it. So bottem line is do I still have a factory warrenty on my engine. I don't have any real issues right now but it would be nice to know.
Thanks
Ed
Old Sep 3, 2009 | 10:09 PM
bismic's Avatar
bismic
The warranty stays with the truck - regardless of the owner. All the 6.0L's have the 5 yr / 100k mile ENGINE warranty.
From the manual
"The 5 yr / 100k warranty coverage (per the manual, page 7) includes the following:
Engine and these components:
cylinder block
heads and all internal parts
intake and exhaust manifolds
timing gear
harmonic balancer
valve covers
oil pan and pump
water pump
fuel system (excluding fuel line and fuel tank)
high pressure lines
gaskets and seals
glow plugs
turbocharger
PCM
electronic driver unit
injectors
injection pressure sensor
high pressure oil regulator
exhaust backpressure regulator and sensor
camshaft position sensor
accelerator switch"
"Furthermore, (under emissions warranty), you will not be charged for labor, diagnosis, or parts for any emissions control device or system for 100k (ie no $100 deductible):
Air flow sensor
Air Fuel Feedback control System and sensors
Cold start enrichment system
Electronic engine control sensors and switches
EGR system
Exhaust manifold
Fuel Injection System
Intercooler Assembly - Engine Charger
Power Train Control Module
Turbocharger Assembly
Also covered by the two emissions warranties (Emissions defect warranty and Emissions performance warranty):
All emisssions-related bulbs, hoses, brackets, tubes, gaskets, seals, belts, connectors, non-diesel fuel lines and wiring harnesses that are used with components on the list above."
Old Sep 5, 2009 | 02:35 PM
FordMan35's Avatar
FordMan35
Thanks Mark.
Ed
Old Sep 5, 2009 | 03:47 PM
bismic's Avatar
bismic
You are certainly welcome.
If you do not have a copy of the owners book and warranty manual, I can send you electronic copies. Just let me know.
