hood stuck shut fix
Old Sep 3, 2009 | 05:14 PM
alwaysFlOoReD's Avatar
alwaysFlOoReD
hood stuck shut fix
My wife's girlfriend's '95 f-150 hood was stuck closed. I reached through the grill with a 1/4" drive ten mm socket and loosened the two bolts holding the latch to the radiator support. Then used a stubby 10 mm wrench, then my fingers to finally remove the bolts. The hood then popped open enough to remove the latch from the hood. Replaced latch to rad support and centered to the hole in the hood. Problem fixed!!!
Old Sep 4, 2009 | 04:58 AM
TexasGuy001's Avatar
TexasGuy001
Thats cool.
Old Sep 4, 2009 | 03:40 PM
Elderstarr's Avatar
Elderstarr
I've made up a specialty bent screwdriver to pull the latch for such an occasion.
What happened? Cable snap/seize?
AXracer
26
Jul 29, 2023 10:54 PM
tip49
29
Jul 13, 2017 06:31 PM
kyle j
Apr 9, 2017 04:10 PM
axidjw
Mar 19, 2017 08:32 PM
Dr. Johnson
Nov 11, 2015 01:29 PM
