Problems, Problems, Problems
Someone suggested to me that it might be a vacuum leak, but i havent been home to check it yet.
Im just wondering if any of you guys would possibly know what is wrong with it. This is my only vehicle and i gotta bum a ride to work and back till i get it fixed.
Sorry for the wall of text but if you have any idea whats causing this I would greatly appreciate the help.
If either one of these doesn't happen, you have a fuel delivery problem, which could be in the tank filter , any inline filters that may be present from the tank to the fuel pump, or the fuel pump itself. If you find a steady supply of fuel when disconnecting the line from the tank to pump (at the pump) via gravity, (maybe 1/4 coffee can in a minute), you can be 98% assured the problem is elsewhere.
If that checks out ok, with the engine off, the air cleaner off, move the carb linkage back (opening the throttle) while looking at the top of the carb. You should see 2 streams of fuel shoot down into the carb. If you don't, the problem is either a fuel filter between the fuel pump and carb, or the carb.
I should have probably told you to do this first, but carefully inspect all vacuum hoses for cracks and to make sure they are hooked up. If the truck was running OK before, they are probably not misrouted, but one may be leaking or unhooked.
You could have a leak on the intake manifold (not likely, but not impossible). There are several different agents you can use to check this ( ranging from oil to WD-40 to Propane to carb cleaner or brake cleaner), but carb cleaner is my favorite. With the engine running and idling, spray (or apply as indicated) the product selected around the manifold and carb base. If you apply it to an area where there is a vacuum leak, the rpm's will rise. ( This can even detect vacuum hose leaks as well).
I don't think it's related to a linkage problem (especially the down shift linkage you suspect, as it really only functions on WOT, not idle), unless it is an idle solenoid adjustment. If giving it slightly more throttle solves the problem, do that while looking at the throttle linkage and what to adjust should become obvious.
If none of this seems to be the problem, check the timing, (if you can), or have it checked at a quick lube joint. These folks are usually pretty good about doing stuff like that for free or next to it, especially if you get an oil change at the same time.
Since you were towing when it first started, it might be a bad torque converter,(or trans) but let's hope is one of these easier and cheaper probs first.
I need to adjust the linkage anyway because it's hard to get it in park now. Sometimes it's starting and throwing its self in park. And that's not good.
That's funny cause I work at a walmart tire and lube but I can't do anything like check the timing because walmart has all kinds of retarded rules and policies. But I'll get a timing light and check it.
But I really appreciate yours guys help.
