PCM Deleted Hail points!
Old Sep 4, 2009 | 04:41 PM
Noa1m's Avatar
Noa1m
Ok, so i've been trolling this board a while now and finally made an account.. But lets skip the bull and cut to the chase.
I have an 86 F150 300.. I took out the PCM and HEI ignition setup and put in the good ol' points setup like a lot of people do for better tuning.. With a handful of clifford parts thrown on there.. :P
Doing a wire tuck job like the little kids in their hondas do.. just looks cleaner So removing fender and firewall sensors is handy as it also would remove the dreaded "across the block" wire harness..
-MAP Sensor delete? Given the PCM is gone, the MAP sensor should not be needed correct?
-All other sensors up to the MAP sensor have been removed, but still have the connections for them just incase, no problems yet.. Been running for 2 years..
