help asap
Old Sep 2, 2009 | 10:31 PM
petroskie's Avatar
petroskie
help asap
hey everybody, im new to this site so here goes. i have a 86 f250 laramie edition, my heater controls dont work, heat or the A/C dont work nor does the speed control. but when i do turn it to defrost on cold or heat it fogs up my windshield really bad, any pointers would be great.
Old Sep 2, 2009 | 10:41 PM
Mustang6147's Avatar
Mustang6147
When it fogs up your windshiled does it smell like anitfreeze???
If not, it should fog then clear, cuz your A/C compressor is running, when the defrost is on, to dry the air... Does your a/c work??
Old Sep 2, 2009 | 11:22 PM
petroskie's Avatar
petroskie
ya it does and it takes alot of cleaner to get it off the windsheild. i replaced the fan but it still turns at a slow speed no mater what, i dont think the a/c works but ill have to check, 2 weeks ago when i turned it on hi to defrost and it fogged up and smelled electrical fire and smoked hasnt done it again
Old Sep 2, 2009 | 11:24 PM
bghnkinf250's Avatar
bghnkinf250
It sounds like you might have a vacuum leak since it defaults to the defrost position if there is a vacuum leak or if the vacuum motors are disconnected. Do you mean speed control for the fan or do you mean cruise control?
Old Sep 2, 2009 | 11:28 PM
petroskie's Avatar
petroskie
heater control, cruise works fine
Old Sep 2, 2009 | 11:39 PM
bghnkinf250
You might want to check the heater core too then.
Old Sep 2, 2009 | 11:45 PM
petroskie's Avatar
petroskie
why the antifreeze fog, and why no speed but slow
Old Sep 2, 2009 | 11:50 PM
bghnkinf250
Antifreeze fog is generally a symptom of a heater core leaking and going bad.
Old Sep 2, 2009 | 11:57 PM
dcassidy's Avatar
dcassidy
My friends heater core went out before and if you left the heater on for a little while, you could physically see antifreeze leeking in from way up under the dash, just a few drops every now and then. Don't know if you would get the same thing or not but thought I would put my 3 cents in.
Old Sep 3, 2009 | 12:54 AM
Sycostang67's Avatar
Sycostang67
It depends on the size of the leak, some will drip onto the cab floor and others will only cause the winfshield to fog horribly.
It sounds like you may have fried that electrical doo-hickey(can't for the life of me remember what it's called.) in the box under the dash. It's a pretty common occurence in these trucks and leaves and pine needles or other stuff falls in and rests on it. It gets pretty hot and will eventually burn all that stuff up.
Old Sep 3, 2009 | 07:54 AM
ctubutis's Avatar
ctubutis
The fan speed resistor thingy? Here's the one with AC:
Old Sep 3, 2009 | 10:30 AM
Sycostang67
Yeah, thats the ticket. Thanks for the assist. I turned 30 last month and was hit with a violent case of CRS.
Old Sep 3, 2009 | 11:22 AM
petroskie's Avatar
petroskie
thanks for the help, so that fan speed resistor, can i get it at any parts house or is it like a special order deal?
Old Sep 3, 2009 | 12:26 PM
bghnkinf250
Both Autozone and RockAuto have the resistor.
Old Sep 3, 2009 | 12:49 PM
petroskie's Avatar
petroskie
thanks so this will fix the fan speed so ill have low and high speed right?
