fuel problems
Old Sep 26, 2009 | 10:52 AM
killjoi's Avatar
killjoi
yeah. and it has power from the relay socket.
Old Sep 26, 2009 | 10:55 AM
subford's Avatar
subford
Sounds like your on the right track with the Inertia switch being bad.
Old Sep 26, 2009 | 11:13 AM
killjoi's Avatar
killjoi
cool. i'll replace it. i was reading up on other people who had problems with it, they said they found ways to bypass it. hows that? do you wire red/yellow to dk green just to start it up? or are they doin somethin else.
Old Sep 26, 2009 | 11:20 AM
subford's Avatar
subford
Yes that is what they are doing.
Old Sep 26, 2009 | 12:59 PM
killjoi's Avatar
killjoi
you think theres a chance this red/yellow wire is bad?
Old Sep 26, 2009 | 01:40 PM
subford's Avatar
subford
If the DK GRN/YEL wire has power and the R/Y wire does not it would mean that the Inertia switch is open.
Nether it is bad or needs to be reset.
If the R/Y wire was bad (shorted to ground) the Fuse would open and you would not have power on the Y wire at the fuel pump relay.
Old Oct 2, 2009 | 12:37 PM
killjoi's Avatar
killjoi
are those relays suppost to click when i turn the key?
Old Oct 2, 2009 | 01:21 PM
subford's Avatar
subford
Yes, both relays will click when you turn on the key and then one second later the fuel pump relay will drop out and you may hear a click.
milehieagle
31
Apr 24, 2021 06:26 AM
Papawheelie
30
Feb 23, 2017 05:14 AM
tylerz71
May 29, 2016 05:39 PM
redman84
17
May 29, 2013 12:38 PM
RANGER589
18
Jun 3, 2011 10:03 AM
