Help me decide... Electric fan or not?
Would I gain anything by putting on an electric fan? I have searched and the reviews are mixed, saying that the alternator will be loaded more often, resulting in zero fuel economy/power gain. I'm mostly driving @ 80km/h, so I know it wont be on all the time.
- The fan... Perma-cool 16", 2000cfm. Variable temp controller. Left over from a dodge project, long since scrapped.
- The truck... 1988 F250 351w on propane. ZF5 speed, A/C, Power Steering. 6"lift, 35" tires.
- Its purpose... Mostly highway/country driving. Towing. Some 4x4 trails and city driving.
Your thoughts?
Your thoughts?
With electric the heat gets hotter faster, because the fans not cooling as much,i personally have no fan on my truck and as long as im not sitting in traffic for ten min at a time its good. Seems electric would be the way to go simply because it isnt on all the time,so alt would only be loaded if sitting still or moving pretty slow. Unless u have air.
I like my electric fan, it doesn't run most of the time. Usually only begins to run when I'm stopped, idling, or using low gear off road. After I shut off the truck it runs for a very long time, but surprisingly doesn't drain the battery. So if you have a bad battery you may want to rig it to a switch, or an ignition source.
I had the big twin Flex-a-lite on my F350. With the electric fan my F350 could not tow my 3500# trailer without overheating. I towed the same trailer with a Toyota Tacoma no problem. So I swapped to a regular fan-shroud-clutch setup and am now able to tow 10,000# trailers with no overheating at all.
Short version: Electric fans are junk if you want to tow. I did get about 1 mpg better with the electric.
The results are in...
I ran the truck to get the baseline temperature setting to when it turns on... took about 20 minutes to begin with. I set it @ about 180*. On the city streets it would intermittently come to life and shut down about 45 seconds later. So far so good.
I wired the system up to my a/c compressor clutch, so I get an extra cold blast of air whenever running it. Works really good.
I don't think it came on down the highway, towing 5000lbs worth of trailer and toys, the temp gauge read around 175*, even when passing the gray-hairs in hondas. When I pulled off the highway, the temperature spiked and the fan whirred for 3 minutes, but didn't hit past 195*.
The real test was a steep, winding gravel road which leads past my house and up to some fishing lakes. Pulling my toys, mostly in 3rd gear, sometimes 4th, the gauge started reaching close to 205* but not for too long. I pulled over and tried adjusting the temp control to come on @ 170* before continuing up the road, and it seemed to do the trick, maintaining 195*.
I now have 2 marks on my adjustment dial, one for standard driving and 1 for towing. I haven't towed anything heavier, nor will I need to. I think it worked well for a swap comprised of leftover parts.
