shift indicator
Old Sep 2, 2009 | 02:42 PM
randy stringham's Avatar
randy stringham
Question shift indicator
How do you fix the shift indicator on the column, the little red pointer has fallin to the right it appears.
Old Sep 2, 2009 | 03:35 PM
brian42's Avatar
brian42
Veteran: Navy
Pull the bottom cover off of the steering column coming out of the dash. There will be a little round **** on a cable. Hang your arm on the transmission handle (shop manual says 6 lbs, but who has a weight lying around to hang on there?) and turn the **** until the indicator is in the middle of the "P". Now place it in other positions and adjust the **** as necessary until you are happy with where your pointer sits in each position.
