Rear differential fit?
Old Sep 1, 2009 | 10:06 AM
Kleenax's Avatar
Kleenax
Would a 1999 F-250 10.5" rearend fit under my 1992 F-250 with a 10.25"? Found one reasonable with 3.73 gears and low mileage; too good to be true?
Spring perches are probably different, eh?
Old Sep 1, 2009 | 10:21 AM
axe_handle's Avatar
axe_handle
This should fit fine, but I don't know about the spring perches. I do know that the 10.5 and 10.25 sterlings are nearly identical internally. In fact, the 10.5 ring and pinion will fit in a 10.25 housing with just a little clearancing for the pinion.
Old Sep 1, 2009 | 03:44 PM
tjc transport's Avatar
tjc transport
i ain't rite
the 99 will have a metric bolt pattern, and the 92 don't. so you will have to carry 2 spare tires.
