If you ordered it from Dieselsite (only vendor that I know of), the gasket and instructions will be included. Should be all that you need, I love mine!!
you reuse your stock ipr unless you ordered a new one. other than that, the gasket is included. just switch over the hpo hose connections and you'll be good to go
Sweet, thanks guys. I probably won't notice much if any difference because still have the stock sticks and tune, but will be ready for the future. I should try and get a gauge hooked up so I can see what the pressure actually is before I replace the stock one.
Did you guys clean your IPR with brake cleaner, I think that is what the directions said.
I ordered and replaced the reservoir gasket at the same time that I did my Adrenaline. It was only $11 or so and the original had 175,000 so it was a good time to replace it. Good luck.
