coolent filter placement
Old Sep 1, 2009 | 03:51 AM
ford7379trucks's Avatar
ford7379trucks
i have a remote oil filter bracket. I was woundering seinse this fits a ford oil fiter FL-1 will a standered coolent filter fit? also how should i install this. Can i just put it in a heater hose?
Old Sep 1, 2009 | 06:59 AM
MoyockPowerstroke's Avatar
MoyockPowerstroke
Whoa...slow your roll....first check to see if someone makes a Non-SCA releasing filter that works with it...then just follow any of the explicit directions on several discussions on this very topic. You can even go to a couple of the sponsors sites DFUser, Dieselsite...and check out their mounting procedures. Most locate the filter housing and filter on the passenger side just left of the radiator support frame facing aft. Another location could be just behind the grill. I'd try to keep it level with the top of the engine though. Add a couple of ball valves to make changing the filter easier.
Old Sep 1, 2009 | 07:01 AM
npccpartsman's Avatar
npccpartsman
I see no reason why you couldn't retro fit it to anything you wanted. I'm not sure there is a "standard" coolant filter anyway. All you need is something to strain your coolant and you don't need a filter that adds any coolant chemicals. You could easily remove the flare fittings that are in the base now and put in some barbed elbow fittings, mount up and go.
JDBeck23
Nov 12, 2012 11:05 AM
tampacamper
6.7L Power Stroke Diesel
Jan 19, 2011 11:35 AM
ford7379trucks
Dec 11, 2009 10:29 PM
ford7379trucks
Oct 8, 2009 05:32 AM
V10RP
Modular V10 (6.8l)
Jun 17, 2009 08:10 PM
