428 Flywheel Question
Old 08-31-2009, 02:29 PM
yellow truck's Avatar
yellow truck
yellow truck is offline
I bought a nicely built 410 to put in my 69 F100 4WD, but I need to buy a 428 flywheel. I see one on ebay (Raceparts - Hawks Racing Billet) but it says it "11 inch long style clutch bolt patter". I asked the guy who said it is set up for the 3 finger style clutch and not a diaphram clutch.
I have the original flywheel on my 360 (with whatever bolt pattern it came with originally), and I have a diaphram clutch in it now. Is there any reason this flywheel won't work with my current clutch?
I hope I can get some help in time to get a flywheel in time to do the swap this weekend.
Old 08-31-2009, 04:39 PM
Argess's Avatar
Argess
Argess is offline
410s and 428s both use a flywheel with a counterbalance for the crank. 360s and 390s do not. Reffered to as "Detroit Balance" vs Zero Balance.
McCloud (spelling) makes a nice flywheel, but pricey. Pretty sure it has both bolt patterns on it.
Alternatively, it may be possible to use your 360 flywheel if you can get a Machine Shop to zero balance your crank
Old 08-31-2009, 04:44 PM
yellow truck
Thanks, I get the part about the counterbalance (hence looking for a 428 flywheel), the sticky bit is the "11 inch long style clutch bolt pattern", does it prevent using a diaphram clutch in place of the old style 3 finger. I have a diaphram on the truck now with the original 360 flywheel, is this something I need be concerned about?
I don't want to take it apart and balance it.
In fact, as I look at a few other ads for flywheels I think the question I should be asking is - do I have an 11 inch pressure plate or did the 360 in a 4WD truck come with a different pressure plate.
Old 08-31-2009, 09:50 PM
Fordworth's Avatar
Fordworth
Fordworth is offline
The flywheel doesn't care what style pressure plate is bolted to it.
billlva
02-06-2013 07:04 PM
bigdan1979f-250
01-06-2012 09:06 AM
bigdan1979f-250
01-05-2012 01:40 PM
oldfordiron
Engine Swaps
04-29-2004 10:18 PM
Quick Reply: 428 Flywheel Question
