Nebraska Chapter Join Chapter, Leader: 97nukeford
'67 F-100 Project
Old 05-16-2016, 11:48 AM
liftnw8z's Avatar
liftnw8z
liftnw8z is offline
(CL) Team Brahma
Coming together nicely. Before long, might look like a truck again lol. Well worth the time spent though.
  #512
Old 05-16-2016, 11:57 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Thanks guys! Fuel tank is next, which will involve moving a couple of the cross members. Also, getting the power steering box mounted.
  #513
Old 05-16-2016, 06:36 PM
Pgh Rebel's Avatar
Pgh Rebel
Pgh Rebel is offline
Looks good Pat!
  #514
Old 05-17-2016, 07:55 AM
Zmonster72's Avatar
Zmonster72
Zmonster72 is offline
Subscribed!
  #515
Old 05-23-2016, 08:07 AM
67nukeford's Avatar
67nukeford
Got hooked up with brand new parking brake cables this weekend (Thanks George!), so I can get that all together when I assemble the back brakes.
  #516
Old 05-23-2016, 08:11 AM
67nukeford's Avatar
67nukeford
On a bad note, the 351 I got out of that 89 is a door stop. Full of water. So, I'll use this for mockup, and plan on getting a crate engine. I didn't buy that truck for the engine, just the transmission. So, this would have been an added bonus. No biggee.
  #517
Old 05-23-2016, 08:16 AM
67nukeford's Avatar
67nukeford
So, on to the transmission. It's pretty grungy, but in good shape, had it checked out after I pulled it out. Before I power wash it, decided to scrap off most of the crap, so I don't cover the driveway in that greasy garbage.
  #518
Old 05-23-2016, 08:18 AM
67nukeford's Avatar
67nukeford
Two hours later, much better. I'm going to have to replace the shifter gasket at the top, I noticed it was leaking, and I don't want water in this thing when I power wash it.
  #519
Old 05-23-2016, 08:24 AM
67nukeford's Avatar
67nukeford
Started working on moving the rear cross member, for the fuel tank installation. Basically, I just took a flap brush to the rivet heads, and then drilled them out. I may end up moving the front cross member forward a bit.
  #520
Old 05-23-2016, 08:26 AM
67nukeford's Avatar
67nukeford
One side has a rivet behind the shackle mount (the other side is gone, or was never installed at the factory). This one is going to be a bear to remove.
  #521
Old 05-25-2016, 06:33 AM
dustybumpers's Avatar
dustybumpers
dustybumpers is offline
Make sure when you change the oil in it, to use Mercon 5.
Transfer case too.Use a new gasket between the transmission and the transfer case, and DON'T use any glue on it.Ford still sells the gasket, but they sell it in a 2 pack. I can dig the part number out for you if they can't find it.
Wade can probably hook you right up on that........
  #522
Old 05-25-2016, 06:50 AM
67nukeford's Avatar
67nukeford
I found a gasket set from American Powertrain, has all the seals and gaskets.
  #523
Old 05-25-2016, 07:48 AM
67nukeford's Avatar
67nukeford
Got the rear cross member loose yesterday. I don't want it sitting all the way back on the frame, I'd like to leave about 3 inches at the back of the frame. So, I'm going to move the front cross member also.
  #524
Old 05-25-2016, 07:53 AM
67nukeford's Avatar
67nukeford
Rivets ground off and drilled out, and then moved the front cross member up about 2 1/2 inches. Leaves me plenty of room to hang the tank, and 3 inches at the back of the frame. Now, time to get some straps made.
  #525
Old 05-25-2016, 07:56 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
You're making it look easy Pat!
Quick Reply: '67 F-100 Project
