Wont Crank
Old Apr 11, 2002 | 08:30 PM
ScottieW's Avatar
ScottieW
Post Wont Crank
1990 F150 XLT has been sitting 4 months - dead battery and out of gas - installed new battery and gas - turns over but wont start - could it be fuel injection stopped up? If so, could anyone tell me what I should do to repair the problem? The truck was running fine when it was parked 4 months ago.
Old Apr 12, 2002 | 02:24 PM
desperado_18_2000's Avatar
desperado_18_2000
Wont Crank
I'd start by spraying some combustible fluid into the throttle body if it were me (it isn't such a bright idea trust me) and see if it will start. if it starts and dies then its your fuel pump, also check all your connections to the battery and under the hood in general. also check for spark.
Old Apr 16, 2002 | 04:42 PM
Wilber15's Avatar
Wilber15
Wont Crank
If it ain't broke.....change stuff till it is!
Don't use Starter fluid...try carb. cleaner. It fires just as good, but won't harm the cylinders. I've talked to people who say not to use it because it harms the cylinders. U may also want to take the plugs out and check for spark. when u have the plugs out, check it they are wet. if they are, it's not a fuel problem. maybe try a compression check too...
Old May 12, 2002 | 10:06 AM
madman211's Avatar
madman211
Wont Crank
If none of this other stuff these guys said works and if you dont have spark
on my 80 ford there
is an ignition box on the drivers side fender replace it costs like
25$ I had the same prob and thats what it was.
Steve
Old May 12, 2002 | 01:28 PM
Wilber15's Avatar
Wilber15
Wont Crank
He has the 90' model, so that iginiton module may be on the front of the distributor....not sure though. check for vaccuum leaks too.
Old May 16, 2002 | 01:44 PM
DavidB's Avatar
DavidB
Wont Crank
Unfortunately, troubleshooting your problem is not so simple. We cannot see, hear, feel what you can see, hear, feel on location with the truck so you have to provide specific information so we can evaluate.
First check the basics. Do you have spark at the plugs? Are you getting fuel in the cylinders? Is the fuel pump running? Do you have good compression on all cylinders? Is the timing correct?
There is no "it turns over but won't crank. What is wrong with it" answer.
If you do not know how to check the things listed above, get someone who does to help you.
We would like to help, but it has to be a partnership. You tell us what you see, hear, etc. We will try to tell you what it means.
Remember, if it has fuel,spark,compression,and correct timing, it will crank and run. If it does not crank and run, one of the four is inadequate or missing.
Feed us information and we will analyze it for you.
Old May 16, 2002 | 10:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
Wont Crank
FarmingFord
Apr 23, 2022 09:53 AM
Ron Hartley
Dec 1, 2014 11:05 PM
hon147
1997 - 2003 F150
Feb 13, 2008 08:57 PM
jake47
1983 - 2012 Ranger & B-Series
May 24, 2007 01:44 AM
elstx
32
Jan 18, 2004 02:57 PM
