Overdrive switch question
Old Aug 30, 2009 | 06:11 PM
Bigol350's Avatar
Bigol350
My overdrive switch light on my 350 wasn't coming on and I replaced the switch but the light still doesnt come on. im not sure if the overdrive is working, the light is just out, or both. any info on how to tell??
Old Aug 30, 2009 | 07:27 PM
clintbonnie's Avatar
clintbonnie
On my 99 there is a overdrive cancel switch fuse... 10A.. On your 2003, can't tell which fuse to check.. different distribution boxes..Check your owner guide for fuse location..
Old Aug 30, 2009 | 08:30 PM
Bigol350's Avatar
Bigol350
thanks for info!
Old Aug 30, 2009 | 08:49 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Most likely the wires to the switch wore through or broke inside the steering column where they enter the shifter handle. Take the plastic cover off of the steering column (three screws from the bottom) and inspect the wires. Either fix them or replace the shifter handle for about $50.
